5 members (ShopRag, kurbside bolter, Ponchogl, cmayna, 1955 1 Series), 107 guests, and 4 robots.
Topics128,268
Posts1,058,375
Members48,485
I am installing new front floors and a new firewall. would it be better to reinstall the doors and keep them latched or just X brace the openings?
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
I would X brace the openings before you remove the offended tins for replacement ..the doors wont hold much as they latch only only on the striker.
I suggest removing the doors tack in your braces ...an then go for removin the floor, also get the floor in before movin on to the firewall ..try an keep it as sound as you can as you proceede, to keep it as square as possible ...Im sure there will be some gents chime in with LOTTS MORE KNOWLEGE on this.
just go slow.
Tim
1952 Chevy Shortbed
Photos in Photobucket
I forgot to mention this is bitchin products recessed firewall and floor kit to match it http://www.bitchinproductsinc.com/07_catalogsec9w-prices.pdf (page 5). I just called them and they recomend doing the firewall first. he said X bracing from door post to door post would keep it from moving
Well then follow there instructions an you will be fine!..post some pics for us all too slober over ..as ya proceeede.
WE LIKE PICS!
Tim
1952 Chevy Shortbed
WE LIKE PICS!
Tim
ok here are some pictures of the progress so far. I bought plasma cutter from e bay, just a cheap chinese made one, that thing is amazing. took maybe 3 mins to cut out the firewall.
http://i11.photobucket.com/albums/a198/ahsum/firewall1.jpg
http://i11.photobucket.com/albums/a198/ahsum/firewall4.jpg
http://i11.photobucket.com/albums/a198/ahsum/firewall7.jpg
http://i11.photobucket.com/albums/a198/ahsum/firewall8.jpg
LOOKIN GOOD!
1952 Chevy Shortbed
Yep!, Looks good!
Boy that makes installing the gauges easy!
Nice work!
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
Nice work!
and wiring
Wow that plasma cutter does a job! What is the brand name and how much did it cost you?
Still trying to get ole Betsy back on the road.
yes they are amazing. I bought mine on ebay and won the bid for $285.00 here is a link to one like mine. watch the auctions you can get one in that price range.
http://cgi.ebay.com/SIMADRE-40A-220...743QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Ahhh. bracing the cab. Boy, does that bring back memories. Lookin' good!
your old fire wall is better than mine...looking good
It's easier to get older than it is to get wiser.
