| | | Forums66 Topics128,153 Posts1,056,849 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Hey guys, I purchased a '60 235 Blue Flame Six to install in my '50 1/2 ton. What are the chances of mating this engine w/ a 700R4? Is it possible? Do the bolt patterns match up? If not, is there a kit that converts it? I know I will need a different cross member and rear diff. to accept the driveshaft....but are there any other obstacles that I may run into? thanks in advance.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You must have a throttle linkage to operate the cable. This is critical on this trans. It has to be right. You will need a cooler in the radiator or an auxiliary cooler. You will need a shifter, either a later model column or an aftermarket like Lokar. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | Wrechbender, can you be a little more specefic about the "throttle linkage to operate the cable"? Pics would be nice if you have done this before.
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
| | | | | Joined: Mar 2005 Posts: 11 Apprentice | | Apprentice Joined: Mar 2005 Posts: 11 | The transmission needs to know the throttle angle to vary the transmission line pressure that is what the cable is for. The older transmissions used a vacuum modulator instead.
34-35 trucks are the greatest
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All the ones i've done were on v-8's with Q-jet. You are probably going to have to improvise it. An explanation is on www.tvmadeez.com They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | tv cable
throttle valve cable that is attached to the trans and the linkage on the carb. There is a couple of bowtie sites that explain it | | |
