5 members (Hotrod Lincoln, Otto Skorzeny, Jack Ryan, Slick Willy, 1 invisible), 123 guests, and 1 robot.
Topics128,162
Posts1,056,925
Members48,458
#412948 05/14/2008 7:03 PM
Hey guys,
I purchased a '60 235 Blue Flame Six to install in my '50 1/2 ton. What are the chances of mating this engine w/ a 700R4? Is it possible? Do the bolt patterns match up? If not, is there a kit that converts it? I know I will need a different cross member and rear diff. to accept the driveshaft....but are there any other obstacles that I may run into? thanks in advance.
Tom Langdon sells these adapters,but I think there's others out there too.
http://www.stoveboltengineco.com/acartpro/product.asp?productid=139
Drew
Riding in the Passing Lane
You must have a throttle linkage to operate the cable. This is critical on this trans. It has to be right. You will need a cooler in the radiator or an auxiliary cooler. You will need a shifter, either a later model column or an aftermarket like Lokar.
1972 Chevy c10 Cheyenne Super
Wrechbender, can you be a little more specefic about the "throttle linkage to operate the cable"? Pics would be nice if you have done this before.
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
Apprentice
Apprentice
The transmission needs to know the throttle angle to vary the transmission line pressure that is what the cable is for. The older transmissions used a vacuum modulator instead.
34-35 trucks are the greatest
All the ones i've done were on v-8's with Q-jet. You are probably going to have to improvise it. An explanation is on
www.tvmadeez.com
tv cable
throttle valve cable that is attached to the trans and the linkage on the carb. There is a couple of bowtie sites that explain it
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
