| | | Forums66 Topics128,018 Posts1,055,341 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | I got my 2 ton '57 and was wondering about the bucket seats in it. Are they something added or are they GM?
'56 panel project
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Wow I have never seen them before but they sure look like the stock bench and seem to belong in there. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Appear to be factory 2 pc optional seats. Not often seen but not totally uncommon either. More prevelent in the GMC line IMO. | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | Thanks, that is very interesting. I normally get stuck with common things. I need to do some searching for some other pictures and compare them to mine.
'56 panel project
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | I'd like to see the seat frame where it mounts to the floor. Does it bolt to the floor using the standard captured nuts like the bench seat? Why would you want a split seat as a new owner back in '56? Is the passenger side removable to allow you to carry cargo up front? Mike B  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | those seats look quite similar to the ones used in panels up to 59, especially the "hinge" - except they had a solid sheet metal back ... I'd bet they were what was used in sedan deliveries, GM "recycled" parts a lot
Bill | | | | | Joined: Oct 2006 Posts: 18 Apprentice | | Apprentice Joined: Oct 2006 Posts: 18 | I'd like to see the seat frame where it mounts to the floor. Does it bolt to the floor using the standard captured nuts like the bench seat? Mike B  Didn't take a picture of that, but someone has added blocks to raise the seats. I'll try to get more pics when i'm back on the farm.
'56 panel project
