| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41189 03/01/2004 10:01 PM | Joined: Apr 2001 Posts: 3 New Guy | | New Guy Joined: Apr 2001 Posts: 3 | Hello, I would like to install my engine this weekend but before I can I need to buy the clutch. That sounds like an easy task however no one can identify the correct pressure to match with my flywheel. The flywheel uses 9 bolts to mount the pressure plate and all 9 were used. All of the clutches that the truck/engine calls for only use 6 bolts to mount the pressure plate. The truck is a 1950 and the engine is a 235 with a Mar 26, 1956 date code and the clutch plate is 10.5 inches. Does anyone know which clutch I need or what vehicle/engine this flywheel was orginally from? Any insight would be helpful... I did see a post in another thread that indicated the flywheel was from a 228 but the local parts guy was not able to help me.
Don.
#41190 03/02/2004 6:29 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Don, I had the same problem last year. Mine is in a 1953 2-ton chevy grain bed. The engine appears to be a 1954 built 261. I ordered two different clutch kits from NAPA and they both turned out to be the 6 bolt. I ended up having my 9 bolt rebuilt by a rebuilder in Fort Worth.
I never did find out the application for the 9 bolt but my other '53 chevy 2-ton winch truck has one too. It has the 53 style 235 in it. | | |
#41191 03/03/2004 2:45 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | I know you have already looked in the 228's but just in case.
The 228 flywheel out of my 51 GMC 1 ton has 9 holes. Center to center measurement on the holes that are closest to being across the center is 11 13/16". From the wear it appears to have used a 10 1/2" clutch disk, or slightly larger. | | |
#41192 03/03/2004 3:08 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | I would try a bel air. I have pulled a 54 235 engine out of a 1946 chev truck that had already been converted like yours. It ended up it was pulled out of a car with a standard trans with the truck trans bolted to it. I have recently purchased a clutch and mine is 9.5 inches but they asked if it was 9.5 or 10.5 diameter.
Hope that helps.
Brent | | |
