| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41173 12/07/2004 3:08 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I installed a dual MC this past Spring and when I pulled my tranny a few weeks ago, in order to pull the engine,I found a small problem. The brake lines that I ran to the new MC interfer with the tranny to the point I had to remove the side plate on the tranny to get it out. I was wondering how others have handled this. I did go to my local auto parts store and get a small length of brake line and using my bender made the tightess bend I could but it still looks to be in the way. Any thoughts? | | |
#41174 12/07/2004 8:21 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you can find a MC that will accept banjo fittings instead of straight lines that works pretty well.
#41175 12/08/2004 3:44 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 |
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#41176 12/08/2004 3:48 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Aren't ther some brass fittings made to make a 90 degree turn out of a master cylinder so you can run the lines straight back or down or whatever and out of the way? I thought I saw some in the "brass cabinet" at the parts store. I could be wrong.
#41177 12/09/2004 2:32 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I looked all over for 90 deg. elbows that would come out of the MC. The problem is that you must have a "hard seating" of this fitting and you don't know where it would point after it seats in the MC. When it tightens up, it might be pointing straight up.
I hit every parts store in town (5) before I figured this out. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#41178 12/09/2004 3:22 AM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | How tight a radius did you get? How tight does it need to be? One thought is maybe the tubing bender you have is the problem. If so, maybe you can find another or have a garage bend it for you. If there is a custom rod shop in town they would probably be able to do it too.
40 Chevy 1/2 ton
