1 members (baldeagle), 89 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#41173 12/07/2004 3:08 PM
I installed a dual MC this past Spring and when I pulled my tranny a few weeks ago, in order to pull the engine,I found a small problem. The brake lines that I ran to the new MC interfer with the tranny to the point I had to remove the side plate on the tranny to get it out. I was wondering how others have handled this. I did go to my local auto parts store and get a small length of brake line and using my bender made the tightess bend I could but it still looks to be in the way. Any thoughts?
#41174 12/07/2004 8:21 PM
If you can find a MC that will accept banjo fittings instead of straight lines that works pretty well.
Paint & Body Shop moderator
#41175 12/08/2004 3:44 AM
smile
#41176 12/08/2004 3:48 AM
smile
Aren't ther some brass fittings made to make a 90 degree turn out of a master cylinder so you can run the lines straight back or down or whatever and out of the way? I thought I saw some in the "brass cabinet" at the parts store. I could be wrong.
#41177 12/09/2004 2:32 AM
I looked all over for 90 deg. elbows that would come out of the MC. The problem is that you must have a "hard seating" of this fitting and you don't know where it would point after it seats in the MC. When it tightens up, it might be pointing straight up.
I hit every parts store in town (5) before I figured this out.
#41178 12/09/2004 3:22 AM
How tight a radius did you get? How tight does it need to be? One thought is maybe the tubing bender you have is the problem. If so, maybe you can find another or have a garage bend it for you. If there is a custom rod shop in town they would probably be able to do it too.
40 Chevy 1/2 ton
