| | | Forums66 Topics128,052 Posts1,055,771 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | i have a double roller timing chain set for my 350 chevy (PO put it on so i have no directions and don't remeber how it was when i took it off... i know shame on me) the crankshaft gear has 3 key ways in it each with the own mark O, A, R, and if you count 4 teeth counterclockwise from each key way theres the matching mark (ex. count 4 teeth counterclockwise from R key way theres the R mark) and the gear also has 2 DEG stamped in it i can draw picture if needed but don't have the time at the moment
Nate | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy OldIronChevy, I am attaching a picture of the Chev. V8 timing chain and gears, note the position of the cam retaining bolts, and the crankshaft keyway relative to the timing marks, this is the straight up factory timing, hope that helps. http://i120.photobucket.com/albums/o178/pintos4me/timingmarks.jpg | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | "0" is straight up factory timing. "A" is advanced, usually 4 degrees "R" is retarded, again often 4 degrees. The advance can help compensate for a worn chain and gears but the racers are the ones that utilize the advanced or retarded cam for dialing in the power in the range they want it.
Evan
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Go with the "O" it is what ya want | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | thanks for the help guys i appriciate it, i figured A and R meant advance and retard i will just go with stock timing which is what i planned on but figured i'd double check and i couldn't remember if you wanted the two dots next to each other and inline or both dots at the top of each gear and inline
thanks again Nate | | |
