5 members (Dennys28, Steelonsteel, Opelika Tom, Guitplayer, Ponchogl), 120 guests, and 0 robots.
Topics128,134
Posts1,056,401
Members48,441
#411161 05/09/2008 1:52 AM
Apprentice
Apprentice
I'm going to put a 350 with a 700r in my 56 TF.
What should I look for in a radiator? I don't have the
original radiator to use as a guide. I don't mind if I
have to rework the radiator support. The TF had a V8
originally.
Bob
Get an aftermarket one from one of our vendors that has a trans. cooler built into it. It will be fresh and clean and capable of keeping your set-up cool,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
an original rad will mount easiest and work fine, especially if you still have the sheet metal pieces that mount the rad back close as original, otherwise no matter the rad, you need a shroud
