7 members (TUTS 59, Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, 1 invisible),
129
Mod | | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#4101 11/11/2002 11:55 PM | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | Hello! I'm working on a '53 3/4 ton custom restoration. Using an inline 292 with NV4500 5speed overdrive transmission. What is a good donor for hanging pedals? I need something which has power brake booster as well as hydraulic master for clutch. There are some "bolt-in pedal kits" out there, but kinda pricey. What can I use from a donor vehicle and modify for my truck. By the way, I'm using the original steering column if that makes any difference. Any help would be greatly appreciated [email protected]
'53 chevy 3/4 ton
| | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | Something to think about when hanging pedals off the firewall is strength. You will have to add support metal and maybe a bracket or two, if not you could break out the firewall. There are plenty of good kits for under the cab. It may seem like a lot money now, but two or three years from now when you are driving down the road, you won't even know you spent the money. Your brakes are the most important item on the truck, don't cut corners, do it once and do it the right way!!  Joe | | |
#4103 11/12/2002 12:34 PM | Joined: Apr 2000 Posts: 58 Member | | Member Joined: Apr 2000 Posts: 58 | using a large piece (1/4" or larger) steel on firewall plus pedals on a bracket that runs from dash to firewall will do you fine. If I remember right I used the pedal system from a early 70's Nova on my cpe. there are a lot of different choices out there just make sure they run back to the dash. | | |
#4104 11/14/2002 10:24 PM | Joined: Sep 2001 Posts: 6 Member | | Member Joined: Sep 2001 Posts: 6 | As long as the firewall and dash are connected to the hanging pedal assembly securely there should not be a problem. Mike K using a large piece (1/4" or larger) steel on firewall plus pedals on a bracket that runs from dash to firewall will do you fine. If I remember right I used the pedal system from a early 70's Nova on my cpe. there are a lot of different choices out there just make sure they run back to the dash.[/QUOTE] | | |
