2 members (Ole49GMC, Hush), 74 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
I would like to put a t5 behind my 216. How can I get an adapter for this?
Rick
Here is some info. Give him a call. Comes highly recommended from those who have dealt with him.
http://www.inliners.org/buffalo/index.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
Rick,
If ypu are trying to put a t5 in a deco truck, you will need an adapter, or the bellhousing that Buffalo Steve has modified to work with the stock pedals. The bellhosuing is actually a 48-53 bellhousing that has had a plate welded to it for the brake and clutch pedals. The adapter plate is used when using the original bellhousing on deco and prewar trucks. There is a Tech tip page, written by John Sandoval, which shows one conversion. Cavebull also did another conversion. Both are well doccumented on this site with photos.
Buffalo Steve lives close enough to me that I often see him at local car shows and swap meets. He wouldn't know me from Adam, but I've spent enough time talking with him to believe he has a real good understanding of the issues in various transmission swaps.
He works out of a back yard shop and I believe is a one man operation. That means he might be a little hard to catch, but well worth the trouble.
He advertises in the 12 Port News, official publication of the Inliners organization and another good reason that all of you folks should join.
Anyone wanting more info please feel free to contact me via e-mail.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Buffalo Enterprises telephone # 360 652 7684
thanks for the replies.
I have a nasty growl comming from the tranny area on deceleration. I have been told sounds like a rear end problem with the sound traveling up the torque tube. I'm going to change out the rear end to a late 70's truck axle with a 3.55. Eventually put a 350 up front but with the news of an adapter, I can get a 5 speed up to the 216 and drive it for now.
