| | | Forums66 Topics128,023 Posts1,055,365 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | What was the widest stock 6 bolt 16” chevy truck wheel with hubcap clips. I have seen 4” and 4 ½”. Are there stock 5”? If so, what year, model did they come on.
Thanks, | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | My wheel width is about 5 1/4 inches from outside to outside. I am told they are 16 inch wheels. I have no idea what that means on whether they are 4" or 4 1/2". I wish somebody would shed some light on that.
I would also like to know what size tire to use.
Donf - thanks for bringing this up.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I measure mine inside the bead and they are 4". I have some which measure 4.5" Tire size if you are going bias-ply which I have (happily) done are 600-16 or 650-16 and radials would be 215-85R16. However my tire dealer would not put radials on my 4" rims as the specs call for a minimum of 6" or 6.5". Having said that there are a lot of old trucks with narrow rims running radials. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There are 5" and 5½" wheels. The 5" were offered on '54s and I'm sure on others. I saw a 5½" at a swap meet with the later style hub cap attachment.
By the way, they are measured bead to bead. | | | | | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | Thanks cletis, that is exactly the information that I was looking for. I will keep a eye out for the 5" with the clips. Oldblue, my experience has been that the outside to outside measurement is about 1 1/8" bigger then the bead to bead width. Not certain if that makes yours 4" or 4 1/2" wide. | | |
