6 members (tclederman, Gray_Ghost, Gdads51, Lightholder's Dad, Paul Mullen, 1 invisible), 184 guests, and 4 robots.
Topics128,077
Posts1,056,019
Members48,433
Apprentice
Apprentice
Does anyone know if or where I can get a new made set of 41-46 pickup cab door hinges? Last year Chevs of the 40s said in a flyer they would have them by spring 2008, but I called today and they now have no plans to make them.
Have you tried Jim Carter Truck Parts, or Bowtie Bits ?
1940 Chevy KC 1/2-Ton
Apprentice
Apprentice
I will call them today. Thank you.
Apprentice
Apprentice
Chevs of the 40s...no dice. Bowtie bits...ditto. Jim Carter...was to have them available after March 2008, now has no idea if or when they will be offering them.
Last edited by poppop's 41; 04/24/2008 4:57 PM. Reason: Still can't find no hinges
Maybe a dumb question but do you have broken ones?? Possibly they could be repaired.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Apprentice
Apprentice
The problem is the half attached to the cab. I have perfect replacement doors with perfect hinge halfs and good pins, but the cab halfs are pretty corroded and I am probably looking at drilling out what is left of the clutch head bolts to remove them. I'll know more when they come off.
I had a similar problem with mine. The bolts holding the hinge half’s to the cab should be non-hardened flat head Phillips with a 5/16 -24TPI. I used lots of liquid wrench and heat then with the help of an impact driver got all but two out. These I drilled and ran a tap through. On one side I had to drill and bush the hinge. By the way if you find a source for new screws please let me know.
Kip....I picked up new stainless screws from an specialty Industrial fastener shop when I did mine. Fit great. Vancouvers' a long way from Michigan but let me knwo if you are stuck.
Hey Bruce...
Could you PM me with the details of that shop? I'm stuck for a few things I may be able to get from them and every other source has come up dry...
Thanks in advance... btw, your truck turned out really nice and it was great to see it saturday at the meet!
~Trev
Thanks Bruce: I'll keep you in mind if I don't turn up any around here
~Jim
Apprentice
Apprentice
Thank you Big Chevy. I'll check them out.
Apprentice
Apprentice
Yesterday, in addition to ordering some cab patch panels, I preordered for 4 brand new 41-46 (possibly 39-46) reproduction hinges from Jim Carter's. They come as complete units (allegedly) and are around $40.00 per unit, so you need 4 units. They are slated for shipping in about a month. Thanks to all.
