| | | Forums66 Topics128,109 Posts1,056,240 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 21 Apprentice | | Apprentice Joined: Jun 2007 Posts: 21 | Does anyone know if or where I can get a new made set of 41-46 pickup cab door hinges? Last year Chevs of the 40s said in a flyer they would have them by spring 2008, but I called today and they now have no plans to make them. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Have you tried Jim Carter Truck Parts, or Bowtie Bits ?
| | | | | Joined: Jun 2007 Posts: 21 Apprentice | | Apprentice Joined: Jun 2007 Posts: 21 | I will call them today. Thank you. | | | | | Joined: Jun 2007 Posts: 21 Apprentice | | Apprentice Joined: Jun 2007 Posts: 21 | Chevs of the 40s...no dice. Bowtie bits...ditto. Jim Carter...was to have them available after March 2008, now has no idea if or when they will be offering them.
Last edited by poppop's 41; 04/24/2008 4:57 PM. Reason: Still can't find no hinges
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Maybe a dumb question but do you have broken ones?? Possibly they could be repaired. | | | | | Joined: Jun 2007 Posts: 21 Apprentice | | Apprentice Joined: Jun 2007 Posts: 21 | The problem is the half attached to the cab. I have perfect replacement doors with perfect hinge halfs and good pins, but the cab halfs are pretty corroded and I am probably looking at drilling out what is left of the clutch head bolts to remove them. I'll know more when they come off. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I had a similar problem with mine. The bolts holding the hinge half’s to the cab should be non-hardened flat head Phillips with a 5/16 -24TPI. I used lots of liquid wrench and heat then with the help of an impact driver got all but two out. These I drilled and ran a tap through. On one side I had to drill and bush the hinge. By the way if you find a source for new screws please let me know. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Kip....I picked up new stainless screws from an specialty Industrial fastener shop when I did mine. Fit great. Vancouvers' a long way from Michigan but let me knwo if you are stuck. | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Hey Bruce...
Could you PM me with the details of that shop? I'm stuck for a few things I may be able to get from them and every other source has come up dry...
Thanks in advance... btw, your truck turned out really nice and it was great to see it saturday at the meet!
~Trev | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks Bruce: I'll keep you in mind if I don't turn up any around here | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Jun 2007 Posts: 21 Apprentice | | Apprentice Joined: Jun 2007 Posts: 21 | Thank you Big Chevy. I'll check them out. | | | | | Joined: Jun 2007 Posts: 21 Apprentice | | Apprentice Joined: Jun 2007 Posts: 21 | Yesterday, in addition to ordering some cab patch panels, I preordered for 4 brand new 41-46 (possibly 39-46) reproduction hinges from Jim Carter's. They come as complete units (allegedly) and are around $40.00 per unit, so you need 4 units. They are slated for shipping in about a month. Thanks to all. | | |
