| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40862 01/03/2005 5:11 PM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I am working on converting an old reo six to full flow oiling. The spin-on filter bracket holds two filters. However, I ordered the gm style adapter not knowing that no gm filters have the bypass valve built into the filter. If I use two, two quart gm filters (each rated 9 gpm hot) will it have enough flowability at cold temperatures that I won't need a bypass valve?
Jason
#40863 01/03/2005 7:26 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The question is,how many gallons per minute is the Reo pump?Is that info published anywhere?As a comparison, a standard Chevy small block pump does about 7-8 gallons a minute. If your adapters' filters are in series, the flow rate is that of one filter not two | | |
#40864 01/03/2005 9:34 PM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | The reo is 8.5 gpm at 3000 engine rpm. The filters are in parallel giving a total of 18 gpm. These are hot flow ratings. The little info that I could find indicated that the bypass valve is needed for plugged filters or cold oil. But since I have two filters, is it OK to not have the bypass valve?
Jason
#40865 01/03/2005 11:00 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Hmmm,I have no clue except engines have a bypass for the reasons you mention. You can do the real world test,see what happens or play it safe and go with Ford spec filters on another adapter | | |
#40866 01/04/2005 1:30 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Do the Ford spin on filters have an internal bypass? | | |
#40867 01/04/2005 1:55 PM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I believe the ford and chrysler filters have the built in bypass filters.
Jason
#40868 01/04/2005 2:04 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The common full size filter for Ford and Mopar does have bypass,I believe it opens at about 12 psi of restriction. During high engine speeds when the pump is at full capacity,the bypass usually opens insuring the engine bearings get full oiling. But you have two filters,perhaps the bypass isn't needed.On the other hand,spending another 50 bucks for a dual filter head for use with bypass filters may be cheap insurance. | | |
#40869 01/05/2005 1:27 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | The local NAPA store let me borrow a wix filter catalog. Near the back of the catalog, there is a listing of filters suitable for remote mount and includes thread size, bypass valve settings, etc. The catalog stresses the need for a bypass valve. There are only a couple of 13/16"-16 filters with a bypass valve. The one recommended, a 1072, is the only one which has a bypass valve, an anti-drainback valve, and a gasket OD that fits the remote filter mount. The 1072 was not a stock item. I'll check into the flow rating of the 1072 and decide whether or not to get the remote mount withe the 3/4"-16 threads. To anyone contemplating a full flow conversion: get the 3/4"-16 type. You'll have a lot more options.
Napa also sells spin-on bypass filters and adapters for large and small gas and diesel engines.
Jason
