1 members (baldeagle),
39
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | I have a 1970 GMC 1/2 ton pu that is a one owner rust-free truck. It spent its life in Alabama and now its up in NJ. What is the best way to undercoat/rust proof the truck so that it will last up north? The rockers and cab corners are notorious for rot so I'd like to do what I can upfront to keep this from happening.
Thanks for the info.
Mac | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Contrary to popular opinion, putting undercoating on a vehicle can promote rust rather than prevent it. Rust occurs in areas where water and debris collect and don't drain properly. Adding thick undercoating only makes it more likely to collect and harder to drain. The best way I know of to prevent rust is to regularly wash salty residue off during the winter and make a habit of physically checking rust prone areas to clear debris manually and unclog drain holes when necessary.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rust on these rigs comes from the inside, where the factory put no coating at all, like inside those rockers, slowly caused by condensation caused by temp and humidity changes .... the only way to "make the truck last" in your area is to keep it in a climate controlled garage .... only use it in fair weather when roads are totally dry
beyond that, if you want to actually use the truck, just do so and fix problems properly as they crop up
Bill | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I agree with both responses. I do spray my under-carriage with rattle can paint every summer after a good wash job with the power washer. It seems to help on my 99 Dakota! | | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | Has anyone used weatherpruf from kano products? http://www.kanolabs.com/ I have had a couple of local guys say thay have drilled access into various body panel locations and sprayed it in. Then close it up with a rubber plug. I've never used it but it looks interesteing. Mac | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I was going to suggest a product called Waxoyl,I've used it for years on many of my cars.It's great for box sections. The only problem is I can't find any dealers in the U.S.A for you!  Sorry! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | well jockbolter . this website claims to be the only one . so i can see it being hard to find. http://www.roversnorth.com/waxoyl/
| | | | | Joined: Jun 2007 Posts: 30 New Guy | | New Guy Joined: Jun 2007 Posts: 30 | Moss Triumph parts sells Waxoyl 1950 3100 3 windo 1951 gmc 102 1958 chevy 3200 1959 gmc 102 1963 c20 1959 buick lesabre 1961 buick lesabre
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Jockbolter, heres my 2 pennies, there is a gun on the market ..sorry I do not have a link right now , but it is for sprayin used motor oil ..in PA they been sprayin used motor oil in the hard too reach spots and on frames forever to keep the nasties we get dumped on the highway every winter at bay. if ya do it before every season it really does help. Tim | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks for the tip SW! Waxoyl also produce a 360 degree spray nozzle for those hard to reach places!! Unfortunately our roads departments are a bit too handy with the rock salt on our roads! You can rot the A** out a 'eurobox' in two to three years over here! , 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Sorry guys but I have to disagree.  We all know what oil does when it mixes with dirt, it turns to that black gunk that build up on everything. Thinking it will keep moisture away is wrong. It holds it in place. The front crossmember on my 38 was full of the stuff because of the front seal leaking over the years. When we pulled the core support off the support bolts were rusted almost completely through and the crossmember itself was less than paper thin and had to be replaced. The best method by far is keeping the area clean of debris. Do as you wish but if you spray anything that will trap & hold dirt you are asking for trouble.
| | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | http://www.rustcheck.com/ RUST CHECK Krown evem if you get 6 spray cans or a gallon and spray it yourself. Something is better than nothing. Used engine oil contains acids collects dirt and is messy. I live in the rust bowl of North America. Backing plates on 5 and 6 year old chev trucks rust off here. LPS3 This is one of the best. All of these products work well. The cold galanize works also | | |
