1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Hey guys, I have a '50 1/2 ton 5 window thats in the process of restoration. I have the original 216...that needs a rebuild. I recently found a '58 blue flame six that's rebuilt for $500. Would this engine work in my truck (front motor mounts)? I'm hoping so because, according to my research, it would boost me from about 90 hp. to 140 hp. would it bolt to the original 3 spd. manual? thanks! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like you have everything figured correctly already. The 1958 passenger car 235 should bolt right in, using the truck clutch (bell) housing and the 216 front motor-mount plate. I think that you could also drill your 1958's plate for attachment of the front motor mount.
Also, use your flywheel and clutch assembly, and your original 3-speed should bolt-up fine.
Maybe someone who has done the same thing will respond (and correct anything that I am wrong about).
Good luck, Tim | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Yes, it will work just fine and $ 500 is a great deal if it really has been rebuilt recently. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The 1958 will give you a lot more power. There are some issues about the water pump/fan placement that you should do a search on. It is good to research those things because depending on how you want to proceed, you may want the more modern setup on the pulleys if you want to go with an alternator. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | FYI, if your truck is titled by the engine number, putting the later model engine in will leave your truck without the title number anywhere on it. If this is the case you will save any future owner a huge headache trying to title the truck by re-titling it yourself after the swap. Just contact your state DMV for their process in getting the new numbers on your title.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | In the situation that Tiny mentions, try checking into getting it titled by the serial number on the ID plate on the A pillar. Some states go by that number anyway. That will eliminate the engine number issue.
Bill Burmeister | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Or stamp the old VIN on the 58 block!!!!!!!! | | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Hi guys, thanks for the advice/info. I'll think I'll take a chance w/ the blue flame six. Re: the title....I'm in Michigan and I believe it is appropriate to title the vehicle w/ the VIN number on the inside of the door. I think...anyways:-) Thanks again! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Hi guys, thanks for the advice/info. I'll think I'll take a chance w/ the blue flame six. Re: the title....I'm in Michigan and I believe it is appropriate to title the vehicle w/ the VIN number on the inside of the door. I think...anyways:-) Thanks again! It's easy to tell. Look at the number on your title & see if it matches your data plate. If not look on the boss behind the distributor. If it's on the boss (the engine number) you'll have some loose ends to tie up.
| | | | | Joined: Jun 2005 Posts: 18 New Guy | | New Guy Joined: Jun 2005 Posts: 18 | Just did the same thing on my '49. I bought a used '55 235 and reused the bell housing from the old engine. However, I used the flywheel and starter from the new engine and the larger (10") clutch kit. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | From Tiny
Quote: "FYI, if your truck is titled by the engine number, putting the later model engine in will leave your truck without the title number anywhere on it. If this is the case you will save any future owner a huge headache trying to title the truck by re-titling it yourself after the swap. Just contact your state DMV for their process in getting the new numbers on your title."
This is great information. I'm going to run into this problem soon and was wondering what to do about it.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Glad I could help. If more people took the time to do that it would save a lot of future headaches.
| | | | | Joined: Sep 2006 Posts: 28 New Guy | | New Guy Joined: Sep 2006 Posts: 28 | Okay guys, One more question re: the Blue Flame six in my '50 1/2 ton.....I ran the numbers on the engine and it's actually a '60 Blue Flame w/ 135 stock hp (out of an Impala). What are the chance of mating this engine w/ a 700R4? Is it possible? Do the bolt patterns match up? If not, is there a kit to convert it? Thanks in advance. | | |
