1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | I am converting to a two filiment bulb and have a basic question, is the turn signal the brighter of the two filiments? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, and in back it's the same one as the brake
Bill | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Yup what Bill said, your runnin lights are the dimmer of the 2 the brights are attention grabbers,IM TURNIN OR STOPPIN...sometimes it actually works! LOL | | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Here's a turn signal question: I have a 12 volt system 1960 GMC 1000. The dash light indicates when the blinker is on for a right turn, but not a left turn. New switch, set right. Lights are working (blinking), just the dash indicator light doesn't blink, and only on left. Any thoughts?
Just learning...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | did you check the bulb in the dash? is it's socket seated properly to get a good ground? check all the wires from the blinker switch and flasher?
Bill | | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Yes, actually redid the dash, new bulbs, cleaned the contacts,etc. Works perfect for right turn, just not left. Been this way since day one. I guess I just need to retrace all the wires for this, it must not be getting feed for the left signal. I am guessing that there is separate feeds for left and right, otherwise it'd make it a four way all the time! Just hoping someone had this trouble before. Call me lazy!
Just learning...
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Longhaul,
Is there a possibility that there is only one dash mounted turn indicator light on this rig. This would flash with a left OR right turn.
This wouldn't explain why yours doesn't operate with a left turn though. Could it be something in the flasher unit itself?
Stuart | | | | | Joined: Jun 2007 Posts: 20 Apprentice | | Apprentice Joined: Jun 2007 Posts: 20 | Yes, just one dash light, lower right one .
Just learning...
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Longhaul, I have enclosed a link for GMC turnsignal problems and diagrams. Looking at a wiring diagram, it sure seems like it has to be the turn signal switch...you indicate you have installed a new one though. http://www.6066gmcguy.org/turnlights1.htmStuart | | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Kanskybrian, are you using one of the kits that include a switch and flasher? I'm trying to install one on my 48 five window (6V) and am having a heck of a time figuring out why the turn signals won't work. The stop and tail light are working fine. | | |
