0 members (), 90 guests, and 1 robot.
Topics128,055
Posts1,055,782
#406400 04/25/2008 6:12 AM
Apprentice
Apprentice
I am converting to a two filiment bulb and have a basic question, is the turn signal the brighter of the two filiments?
yes, and in back it's the same one as the brake
Yup what Bill said, your runnin lights are the dimmer of the 2 the brights are attention grabbers,IM TURNIN OR STOPPIN...sometimes it actually works! LOL
1952 Chevy Shortbed
Photos in Photobucket
Apprentice
Apprentice
Here's a turn signal question: I have a 12 volt system 1960 GMC 1000. The dash light indicates when the blinker is on for a right turn, but not a left turn. New switch, set right. Lights are working (blinking), just the dash indicator light doesn't blink, and only on left. Any thoughts?
Just learning...
did you check the bulb in the dash? is it's socket seated properly to get a good ground? check all the wires from the blinker switch and flasher?
Apprentice
Apprentice
Yes, actually redid the dash, new bulbs, cleaned the contacts,etc. Works perfect for right turn, just not left. Been this way since day one. I guess I just need to retrace all the wires for this, it must not be getting feed for the left signal. I am guessing that there is separate feeds for left and right, otherwise it'd make it a four way all the time! Just hoping someone had this trouble before. Call me lazy!
Just learning...
Longhaul,
Is there a possibility that there is only one dash mounted turn indicator light on this rig. This would flash with a left OR right turn.
This wouldn't explain why yours doesn't operate with a left turn though. Could it be something in the flasher unit itself?
Stuart
Apprentice
Apprentice
Yes, just one dash light, lower right one .
Just learning...
Longhaul,
I have enclosed a link for GMC turnsignal problems and diagrams. Looking at a wiring diagram, it sure seems like it has to be the turn signal switch...you indicate you have installed a new one though.
http://www.6066gmcguy.org/turnlights1.htm
Stuart
Kanskybrian, are you using one of the kits that include a switch and flasher? I'm trying to install one on my 48 five window (6V) and am having a heck of a time figuring out why the turn signals won't work. The stop and tail light are working fine.
Montana first time diy rebuilder.
1948 Five window, 3/4 ton, 216 motor, four speed, six volt, mostly original
Webshot Photos
