2 members (Bill Hanlon, Nuts&Bolts), 25 guests, and 4 robots.
Topics128,014
Posts1,055,324
Members48,419
#407137 04/27/2008 5:28 PM
I have a 1970 GMC 1/2 ton pu that is a one owner rust-free truck. It spent its life in Alabama and now its up in NJ. What is the best way to undercoat/rust proof the truck so that it will last up north? The rockers and cab corners are notorious for rot so I'd like to do what I can upfront to keep this from happening.
Thanks for the info.
Mac
Ex Hall Monitor
Ex Hall Monitor
Contrary to popular opinion, putting undercoating on a vehicle can promote rust rather than prevent it. Rust occurs in areas where water and debris collect and don't drain properly. Adding thick undercoating only makes it more likely to collect and harder to drain. The best way I know of to prevent rust is to regularly wash salty residue off during the winter and make a habit of physically checking rust prone areas to clear debris manually and unclog drain holes when necessary.
Tiny #407157 04/27/2008 6:26 PM
the rust on these rigs comes from the inside, where the factory put no coating at all, like inside those rockers, slowly caused by condensation caused by temp and humidity changes .... the only way to "make the truck last" in your area is to keep it in a climate controlled garage .... only use it in fair weather when roads are totally dry
beyond that, if you want to actually use the truck, just do so and fix problems properly as they crop up
Flxible #407249 04/27/2008 10:39 PM
I agree with both responses. I do spray my under-carriage with rattle can paint every summer after a good wash job with the power washer. It seems to help on my 99 Dakota!
Has anyone used weatherpruf from kano products?
http://www.kanolabs.com/
I have had a couple of local guys say thay have drilled access into various body panel locations and sprayed it in. Then close it up with a rubber plug. I've never used it but it looks interesteing.
Mac
I was going to suggest a product called Waxoyl,I've used it for years on many of my cars.It's great for box sections. The only problem is I can't find any dealers in the U.S.A for you! dang
Sorry!
More pix on Flickr.
well jockbolter . this website claims to be the only one . so i can see it being hard to find.
http://www.roversnorth.com/waxoyl/
1955 Chevrolet 3100 2nd
1954 International Harvester R-110
My Webshots Pictures
Moss Triumph parts sells Waxoyl
1950 3100 3 windo
1951 gmc 102
1958 chevy 3200
1959 gmc 102
1963 c20
1959 buick lesabre
1961 buick lesabre
4 bolts #408350 04/30/2008 3:12 PM
Jockbolter,
heres my 2 pennies, there is a gun on the market ..sorry I do not have a link right now , but it is for sprayin used motor oil ..in PA they been sprayin used motor oil in the hard too reach spots and on frames forever to keep the nasties we get dumped on the highway every winter at bay.
if ya do it before every season it really does help.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Thanks for the tip SW! Waxoyl also produce a 360 degree spray nozzle for those hard to reach places!!
Unfortunately our roads departments are a bit too handy with the rock salt on our roads! You can rot the A** out a 'eurobox' in two to three years over here! ,
More pix on Flickr.
Ex Hall Monitor
Ex Hall Monitor
Sorry guys but I have to disagree. eek We all know what oil does when it mixes with dirt, it turns to that black gunk that build up on everything. Thinking it will keep moisture away is wrong. It holds it in place. The front crossmember on my 38 was full of the stuff because of the front seal leaking over the years. When we pulled the core support off the support bolts were rusted almost completely through and the crossmember itself was less than paper thin and had to be replaced. The best method by far is keeping the area clean of debris. Do as you wish but if you spray anything that will trap & hold dirt you are asking for trouble.
Tiny #408828 05/01/2008 10:04 PM
http://www.rustcheck.com/
RUST CHECK
Krown
evem if you get 6 spray cans or a gallon and spray it yourself. Something is better than nothing. Used engine oil contains acids collects dirt and is messy. I live in the rust bowl of North America. Backing plates on 5 and 6 year old chev trucks rust off here.
LPS3
This is one of the best. All of these products work well. The cold galanize works also
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
