Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (klhansen, Woogeroo, J Lucas, 1 invisible), 54 guests, and 9 robots.
Topics128,010
Posts1,055,299
Members48,419
#40692 06/04/2003 8:00 PM
Pal
Offline
I may have a bit of a problem. My engine shop is having trouble finding an acceptable 250 to rebuild. Truck is a 68 c-10. If I upgrade to a 292, does the exhaust and intake manifold stay the same (like F**d's 289/302)? Also do the motor mounts line up? Sorry to bug you guys but I'm kinda new to the six-bangers.
35 + years of rollin' steel!
#40693 06/04/2003 8:39 PM
Anonymous
Unregistered
Anonymous
Unregistered
The motor mounts are different - the 292 has one mount offset relative to the 230/250 series.
#40694 06/04/2003 8:42 PM
Would a decent 230 block work for you?
#40695 06/04/2003 8:44 PM
I can't say for certain that the manifolds are the same between the 194/230/250 and the 292 engines, although I think they are. Aftermarket manifolds and headers are usually listed as fitting all four sizes.
Engine mounts for the 292 are the same on the driver's side, but the passenger side engine mount is moved forward to the location of the smaller engines' fuel pump.
If you can't find a good 250, how are you going to find a 292? From what I've seen, the 250 is a lot more plentiful. It doesn't have to be from a truck, the car 250 is the same block. Check out Leo Santucci's "Chevrolet Inline Six-Cylinder Power Manual" and the Inliners site for more info.
1954 GMC De Luxe COE
#40696 06/04/2003 8:44 PM
Pal
Offline
A 230 would work, but hate the idea of dropping down in size/hp.
#40697 06/04/2003 9:38 PM
I'm having a hard time believing that you can't find a short block for a 250. I could go out and find a railcar load around here. You won't go wrong with the 292, though. And you can still buy a 292 in a crate if you want stock. Usually cheaper than a local rebuild.
Fred
52 3600
69 C-10
#40698 06/04/2003 9:53 PM
Pal
Offline
Nevermind guys. Thanks for the help. My shop found a good 250. Good info for future referance, however.
#40699 06/05/2003 6:52 AM
Is there some sort of mount adapter for the 292 that lets it fit where a 250 would go? I can't believe they put different crossmembers in to fit 250/292/327/350's. There has to be some way they adapted, doesn't there?? Joe
#40700 06/05/2003 12:19 PM
I can clarify GMPanel's post about the manifold size. They are definitely the same for 194/230/250. Good thing, or I would never have found a replacement (from a 250) for the one that broke into two pieces this weekend (on my 194).
Jim
Jim
#40701 06/05/2003 6:52 PM
Anonymous
Unregistered
Anonymous
Unregistered
Joe, there is no crossmember. The motor mounts are side mounts that go between the side of the block and the frame. The 292 has the fuel pump in the middle of the right side of the block(the easiest way to spot a 292). The right motor mount and the fuel pump swap positions between a 250 and a 292. The 292 right motor mount just gets moved forward on the frame. Just means drilling some new holes for the bolts. On later trucks where the 292 was an option the holes are usually already there.
#40702 06/05/2003 9:42 PM
You may not have to even drill the holes. Look back a bit from the current mount and you'll probably see a couple of holes already in the frame, just right spacing for a motor mount int he right spot for a 292. smile
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
#40703 06/06/2003 6:37 AM
Well that makes since! Some reason I thought they had full crossmember motor mounts. I guess I never realy looked at one. Just used to seeing my Dodge. Joe
