| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I did a search and came up empty, so I thought I would ask here. If I put this in the wrong forum please forgive me. So here goes. I spotted a pretty cool compass on Ebay. The draw back is there is no fluid inside the compass. Can anyone tell me what liquid is used inside the compass? I looks to me in other compasses that the liquid is slightly viscus, so not plain water. Any ideas or comments would be welcomed. | | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Boat compasses were filled with mineral oil. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hi Jim, That makes sense. Mineral oil won't thicken up in cold weather, and is water clear. If the compass on Ebay stays cheap I may get it and try to rehab it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might be glycerin or glycerol, also doesn't change volume with temp changes .... and if ya lose yer way you can eat it for some calories  getting cheap I think, as it's a byproduct of biodiesel production  Bill | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hmmm, I like glycerin better. They use it to give cheap red wine a better "mouth feel" So if I keep a jug of red wine in the truck, I get the calories from the glycerin plus I don't care if I'm lost! lol | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Alcohol....Don't freeze, won't inhibit compass swing.... | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | If you go to an aircraft supply store they sell actual compass fluid, I have some at home, I'm almost certain it is the same as stoddart solvent. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Old aircraft ones where filled with alcohol I believe. Also have heard the term "whiskey compass". | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | While you are at the aircraft supply store get yourself an altimeter key. They work well on compasses. | | |
