2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
1945RC60
Unregistered
1945RC60
Unregistered
Well I finally got the 66 C60 on the road. Made two trips to the stone place. Both 8 mile round trips went flawlessly. Can haul 5 tons per load. Steering a little loose and 2 of 3 exhaust pipe studes broken off manifold so it is a little noisy. Any fix for this on a 292 or anyone know of cheap manifolds? That is all.
glad maiden voyage went smoothly
i would try to drill them out and bolt them or retap it. or find another manifold
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
I really like that truck I have a 4000 series GMC that has treated me well and I work it most every day.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
A torch and some vise grips will fix the stud problem if there's enough left to get a grip on the broken off ones. Heat the ear of the manifold, not the stud, until it's red, and try to move the stud a little. It will probably move a fraction of a turn, and tighten up again. Keep up the heat/turn sequence until you can back the stud all the way out, then move on to the next one. Be patient! Once the studs are out, clean up the threads in the manifold with a tap, and install new studs from the FLAPS. They should be in the "help" section that most parts stores have. I'd reccomend changing all three studs, as the one remaining is probably pretty tired too.
If you can't get a grip on the broken-off stud, it's time to drill & tap. Just be sure to get the first hole (about 1/8" diameter) as close to center as possible, and work up carefully 1/16" at a time to 5/16". Then use a 3/8"X16 tap to clean out the remaining threads. Use LOTS of oil or tapping fluid, and work slowly, rocking the tap back and forth every half turn or so. An off-center hole will result in leaving a portion of the steel stud in the cast iron manifold, which is a sure way to break off the tap when you try to clean out the threads!
The above procedure works much better with the manifold off the engine, and clamped securely in a vise.
1945RC60
Unregistered
1945RC60
Unregistered
I only wish it was that easy. The manifold has three tabs on it that a bolt or stud screws into. Two of those ears are broke off.
