4 members (Ridgeback, baldeagle, stlcardinalsguy, Peggy M), 43 guests, and 5 robots.
Topics128,012
Posts1,055,317
Members48,419
#405610 04/23/2008 3:23 AM
Is there an online tool anywhere that you can input your engine serial # and get some background on year of production or other details? I've done a google search and had no luck at all with this...
My engine was originally believed to be a 327 when I bought my truck, but is now believed to be a 350... whatever the case I'd like to know for sure...
Serial Number (found on top driver's side) is 3892657
Any ideas??? Thanks in advance for your help... headscratch
~Trev
*BuMp*
3B Offline
Hy 37ChevTruckGuy,3892657 is identified as a 1967 4" bore block, could be used to build a 302, 327, or 350, but it will have small main bearing bores, hope that helps.
3B #405675 04/23/2008 6:59 AM
Thanks a lot, 3B... at least that gives me a year to go on if nothing else...
I look forward to seeing you at the BC Bolter meet this weekend and appreciate you taking the time to look up this info for me! smile
~Trev
http://www.mortec.com/
Its a 1967 327 engine with two bolt mains
