3 members (Wayne67vert, crenwelge, 1 invisible),
475
Mod | | | Forums66 Topics128,282 Posts1,058,494 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40444 01/07/2003 1:46 AM | Joined: Dec 2002 Posts: 3 Member | | Member Joined: Dec 2002 Posts: 3 | I tried to ask this ? last night, but don't think I got it in correctly so anyone could see it. My 1962 235 engine reads between 110 lbs and 117 lbs of compression. Is this in the OK zone. I have to pull the head to fix a bad exhaust valve, and we could rering the engine if it needs it, but don't want to do it if it is not neccesary. A po told me the engine has about 20,000 miles on it since an overhaul. On first revolution of the crank my compression tester reads over 100lbs, and that was testing it dry, no oil in the cylinders. | | |
#40445 01/07/2003 8:10 PM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Hi,
Yes I just did a compression and I got 140# with most engine over a hundred is go for a stock engine. | | |
