Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, MNSmith), 240 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
I tried to ask this ? last night, but don't think I got it in correctly so anyone could see it. My 1962 235 engine reads between 110 lbs and 117 lbs of compression. Is this in the OK zone. I have to pull the head to fix a bad exhaust valve, and we could rering the engine if it needs it, but don't want to do it if it is not neccesary. A po told me the engine has about 20,000 miles on it since an overhaul. On first revolution of the crank my compression tester reads over 100lbs, and that was testing it dry, no oil in the cylinders.
Hi,
Yes I just did a compression and I got 140# with most engine over a hundred is go for a stock engine.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
