2 members (55shaker, Hotrod Lincoln), 137 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
Z
Z Offline
My temperature sending line, the one with the gas in it, broke and thus the gas leaked out. I really want to stay original but don't want to spend $300 on a entire new gage assy. does anybody know if I can disconect this line from the gage and where I can get a new line that screws into the engine block as well as the back of the original guage?
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
have you looked in the swap-meet here?
I've had gauge repairs done by Williamsons in Chester Arkansas - they will replace the tube and calibrate the gauge, seems like I paid about $65 but it was a few years ago. They also do cosmetic restoration but that costs extra.
They now fill that tube with methylene chloride (paint stripper solvent base) I believe. Carter's has them rebuilt by a guy locally and it's less than $50/guage. If you call them, they can hook you up. Find a pre '50 GMC 228 and you can remove the electric temperature sender and the thermostat housing together. Then replace your capillary tube guage with an electric one from a GMC! Post 1950 GMCs used the capillary guages too.
I bought a used gauge from Mothertrucker from the swap meet. It works great.
54 3100 with 235
62 flatbed dump C60 with 261
I bought a rebuilt gauge from BowTie Bits out of Kansas. It was only $75 and works great. Joe
Z
Z Offline
Thanks so much guys I will call Mr. Carter. Zach
