2 members (2-Ton, JW51),
67
Mod | | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 Apprentice | | Apprentice Joined: Nov 2006 Posts: 33 | I am putting the seat back into my 46 half ton.. The top of the seat back hooks into slots on the rear wall of the cab.. The bottom of the seat back has two metal brackets extending down but whwre do they go? I read somewhere that the seat was adjustable. How does that work? I've looked at lots of pictures but never saw one of behind the seat. What's back there?
Experience is the ability to recognize a mistake when you make it again....
| | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | The back seat hangs off of the back cab wall and the bottom of it drops into the back of the seat bottom (other removable section). The seat bottom has two pins in front that drops into the front of the base. There isn't any seat adjustment. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | 4d6,
I have read the same thing and also wondered what they considered adjustable back then. To John's point, I also fail to see how it is adjustable.
Tim
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I have a 46 and have not seen any way to adjust the seat, it pretty much sits where it sits and thats it.
Ed | | | | | Joined: Nov 2006 Posts: 33 Apprentice | | Apprentice Joined: Nov 2006 Posts: 33 | The catalogs show a "seat bumper".. Wonder what that does?
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I don't have the orig. seat anymore, but when I did the two mounting brackets that bolted to the seat riser had two sets of holes for the pins that steppenwood mentioned. They were only about 1" apart (front to back) That's the only adjustment there is. Not very usefull. George | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Well, not to dissagree with you all, but there are 3 holes in the seat that the pin can go trough, which allows minimal adjustment of the bottom seat forward and back. (Or a previous owner drilled the other 2 holes in my truck) As the bottom seat is repositioned, the top bench changes position even slighter. | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Well I finally got around to checking the seat bracket on my truck. And I'll be damned if it ain't adjustable! You learn something new every day. It's not much of an adjustment but it's there allright. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Yup my ’41 is the same. Pin sticking down from the front of the seat frame enters one of 3 holes in the slide guide bolted to the gas tank frame. The seat bottom has two slots at the back that engage the tabs on the bottom of the seat back. Darned simple. | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Thats cool, I thought it was a one size fits all, I have short legs so this may help.
Ed | | |
