5 members (Southerntruck, Wally / Montana, Gray_Ghost, Steelonsteel, 1 invisible), 86 guests, and 0 robots.
Topics128,050
Posts1,055,761
#402493 04/15/2008 4:03 PM
4D6
Offline
Apprentice
Apprentice
I am putting the seat back into my 46 half ton.. The top of the seat back hooks into slots on the rear wall of the cab.. The bottom of the seat back has two metal brackets extending down but whwre do they go? I read somewhere that the seat was adjustable. How does that work? I've looked at lots of pictures but never saw one of behind the seat. What's back there?
Experience is the ability to recognize a mistake when you make it again....
4D6 #402722 04/16/2008 12:35 AM
The back seat hangs off of the back cab wall and the bottom of it drops into the back of the seat bottom (other removable section). The seat bottom has two pins in front that drops into the front of the base. There isn't any seat adjustment.
4d6,
I have read the same thing and also wondered what they considered adjustable back then. To John's point, I also fail to see how it is adjustable.
Tim
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Sheridan #402928 04/16/2008 1:49 PM
I have a 46 and have not seen any way to adjust the seat, it pretty much sits where it sits and thats it.
Ed
Ed Blouch #403474 04/17/2008 8:00 PM
4D6
Offline
Apprentice
Apprentice
The catalogs show a "seat bumper".. Wonder what that does?
4D6 #403526 04/17/2008 11:42 PM
I don't have the orig. seat anymore, but when I did the two mounting brackets that bolted to the seat riser had two sets of holes for the pins that steppenwood mentioned. They were only about 1" apart (front to back) That's the only adjustment there is. Not very usefull.
George
46forme #403982 04/19/2008 12:18 AM
Well, not to dissagree with you all, but there are 3 holes in the seat that the pin can go trough, which allows minimal adjustment of the bottom seat forward and back. (Or a previous owner drilled the other 2 holes in my truck) As the bottom seat is repositioned, the top bench changes position even slighter.
Well I finally got around to checking the seat bracket on my truck. And I'll be damned if it ain't adjustable! You learn something new every day. It's not much of an adjustment but it's there allright.
Yup my ’41 is the same. Pin sticking down from the front of the seat frame enters one of 3 holes in the slide guide bolted to the gas tank frame. The seat bottom has two slots at the back that engage the tabs on the bottom of the seat back. Darned simple.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #405010 04/21/2008 6:50 PM
Thats cool, I thought it was a one size fits all, I have short legs so this may help.
Ed
Moderated by  ndkid275, Phak1
