7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP),
111
Mod | | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 10 New Guy | | New Guy Joined: Jul 2007 Posts: 10 | I ordered a adapter from classic parts and Corvette style master cylinder from Southern car Parts. The end where the push rod goes in is shallow. Classic parts requires it to be one inch deep so the rod doesn't fall out. Can't seem to find a replacement master cylinder locally with the deep indent. Anybody have experience or suggestions for what model or casting number I need? Wayne | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Take a magnet and see if that indentation is steel or aluminum. If it's steel, pop the snap ring off and remove the plate and see if the indentation goes in further. Alot of masters fit different applications, some needing different depth indentations. So, they rebuild them with the same parts and cover the deep hole when a shallow is needed, sometimes, Scott | | |
