7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | My Trans. Is acting up. If I pull the gov. out how can I tell if it,s defective? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Usually what happens is the gear wears out. It's made of some sort of plastic, and does seem to be the main sorce of problem woth the 700R4. It is a dealer item, and you will have to drill your own hole for the retainer pin. You'll most likely see the center worn out of the gear where it rides on the drive gear.
Bill Burmeister | | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | If your governor is from Illinois I can GARANTEE it's defective!!!!!!! he he he..... couldnt pass that one up.
1965 chevy c-80 409 5-2 20000 original miles. 1965 chevy c-60 348 5-2 single axle tractor. 1952 chevy p/u 235 4 speed restored. 1965 chevy c-60 couch. One grouchy wife. FOR SALE....CHEAP!!!! The future is not what it used to be..... Have a new pair of metric vise-grips and large metric hammer, can fix anything...
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | He moved? You mean our Colorado Governor moved to Illinois? Gee Thanks, I hadn't heard! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If your governor is from Illinois I can GARANTEE it's defective!!!!!!! he he he..... couldnt pass that one up. Good one!
Bill Burmeister | | | | | Joined: Mar 2008 Posts: 33 Apprentice | | Apprentice Joined: Mar 2008 Posts: 33 | Iff its hanging downshifts when you come to a stop the spool is sticking. Polish it with a little scotchbrite pad and reasemble. Try some shift additve with "esters" fixes notoriuosly sticky 700s right up.
I suffer from ADAD (Advance Design Acquisition Disorder)
