1 members (2-Ton), 167 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#403094 04/16/2008 9:21 PM
Riding in the Passing Lane
My Trans. Is acting up. If I pull the gov. out how can I tell if it,s defective?
1972 Chevy c10 Cheyenne Super
Usually what happens is the gear wears out. It's made of some sort of plastic, and does seem to be the main sorce of problem woth the 700R4. It is a dealer item, and you will have to drill your own hole for the retainer pin. You'll most likely see the center worn out of the gear where it rides on the drive gear.
Bill Burmeister
If your governor is from Illinois I can GARANTEE it's defective!!!!!!! he he he..... couldnt pass that one up.
1965 chevy c-80 409 5-2 20000 original miles.
1965 chevy c-60 348 5-2 single axle tractor.
1952 chevy p/u 235 4 speed restored.
1965 chevy c-60 couch.
One grouchy wife. FOR SALE....CHEAP!!!!
The future is not what it used to be.....
Have a new pair of metric vise-grips and large metric hammer, can fix anything...
He moved? You mean our Colorado Governor moved to Illinois? Gee Thanks, I hadn't heard!
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Good one! grin
Bill Burmeister
U
Apprentice
Apprentice
U Offline
Iff its hanging downshifts when you come to a stop the spool is sticking. Polish it with a little scotchbrite pad and reasemble. Try some shift additve with "esters" fixes notoriuosly sticky 700s right up.
I suffer from ADAD (Advance Design Acquisition Disorder)
