4 members (Shade Baby, 1955 1 Series, 55shaker, Wally / Montana), 119 guests, and 4 robots.
Topics128,139
Posts1,056,448
Members48,441
Apprentice
Apprentice
I have a '49 3100 and the lines from the tranny cooler are leaking. I know, not exactly stock (TH350). There are hard lines coming from the tranny and flex hose coming from the cooler. Joining the two are some type of compression fittings, and the junction is near the motor mounts. The compression fittings are leaking. I've tried to tighten them up to no avail. Are these necessary? I would like to remove
1949 5 Window 3100
yes, there is pressure on the trans cooler lines, however it is under 40 psi. If you are using compression fittings and it is leaking, something is wrong. I would run new lines.
Watch for housing cracks where the brass cooler line adapters go into the aluminum. People over tighten them and crack the trans. After that the only fix is replacement,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Also only use rubber hose that is intended for transmission fluid. Regular fuel line won't last.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
The trans cooler lines carry "lubrication" pressure, usually 30 lbs. or so on the line coming from the trans to the cooler. The return line carries noticeably less than the other one.
Compression fittings have a habit of leaking if they're overtightened and the ferrules are distorted. The only good fix is to cut the line back about 1/2" and put a new ferrule onto an undamaged section of line. The quick fix is to eliminate the compression fitting altogether, and simply put a small bulge in the end of the line with the first stage of a double flaring tool, creating a knot to retain the rubber hose, then clamp it with a screw-type fuel line clamp. Trans cooler hose is a little heavier than rubber fuel line, and rated for higher temperature and pressure. Another good option is to use the same type hose that's found on the return side of a power steering pump.
