| | | Forums66 Topics128,175 Posts1,057,119 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I need a van and was considering a early 64-70 chevy van.I thought it could be cool, as I like older stuff. Any way wondering if ther were any van guys here, and if any one could give any advise on what to look for when buying one of these old vans. any special spots to look for bad hidden structual rust? Not easy finding one up here in New England, so I'm thinking the were all eaten up by rust. Thanks
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I worked on commercial vans for many years. The places to look for rust are about the same as any other vehicle. The frame & cab supports. These were bad about the side panels & side doors. You are right, it will be hard to find a good one there in the rustbelt. You will need to go south & or west to find one. The 71 up are better. They had beefier front ends with disk brakes. A v-8 is better then a six. The auto trans is better because the standard shift linkage gets sloppy. Technically these would not be considered stovebolts but this website is open to 72 on back GM. trucks. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I just like the 64-70 style snub nose.
| | | | | Joined: Jun 2007 Posts: 30 New Guy | | New Guy Joined: Jun 2007 Posts: 30 | In my opinion any straight six chevy from the antique era could be considered a stovebolt. The early vans are cool. They have more than enough power with the six, their manual drum brakes are more than capable, and they are a blast to drive. Column manual shift is fine as long as they linkage is not completely worn out. They rot structurally where steering box mounts and where leaf springs mount. There are patch panels available for other exterior areas where they tend to rot. 1950 3100 3 windo 1951 gmc 102 1958 chevy 3200 1959 gmc 102 1963 c20 1959 buick lesabre 1961 buick lesabre
| | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | Although technically "stovebolt" would only refer to the straight sixes, I think I read somewhere that here on Stovebolt, any chevy truck '67 or earlier is honorarily given that title.
I know, for instance, that my '60 has a 283 in it, and I've never been told to leave.
B | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Well if any one knows of one around new england, please give me a shout. My plan would be to either keep the straight 6 or put in a built 4.3, either way running a 700r4 overdrive. Dosen't take much to move them any way. I don't think I find one close to here unless I luck out.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I think I read somewhere that here on Stovebolt, any chevy truck '67 or earlier is honorarily given that title. The actual language says pre '73 and though this is really a truck site, I've seen guys with cars accepted and treated well--they just don't find a lot of help on anything except drive train issues.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2005 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 76 | Moderator's note: Craiglist item deleted. Not allowed in General Truck Talk
