| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | can anyone give some education on the braking systems of the trailers back in the 40,s thru 60,s. the 1952 coe i just bought would make a nice road tractor. what would be the general size that it would have pulled in the day?/ thanks for the help already. with the addition of this coe and maybe a trailer in the future to what i already have i may be selling my lawn mower, since there is no grass that is not in the shade of a ole bolt.
http://www.flickr.com/photos/11977495@N06/sets/ 1952 COE 1952 3100 1953 3100 1950 6400 1951 Suburban
| | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 |
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I assume your referring to semi trailers. Vacuum brakes were used into the late 40's/early 50's and them the industry standardized on full air. Does your tractor have air brakes? If not then it would be very difficult to change it to full air and very, very expensive. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | My '52 GMC 450 COE, http://www.classiccoe.com/friends/spanky/1952_spanky_1c.jpg was originally a hydraulic brake roadtractor. It had a Bendix vacuum operated hand control valve, that was mounted to the steering column, for use when applying the trailer brakes. That COE of yours would look great as a roadtractor. That's was the first thing I thought of, when I saw it. I've still got the fifth wheel off of mine, out in the shop, if your're interested in it. Already traded the saddle fuel tank, to another guy. | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190210824178here is the link to my coe thanks to spanky. yes semi trailer is what i was referring too. spanky, thanks i am interested in the 1/5 wheel.
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I used to drive a tractor trailer rig in the late 50's that had hydraulic bralkes on the tractor with a air compressor for the trailer brakes that had a hand control valve on the steering column. Cleon
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | When I purchased my trucking business I ended up with a couple semi trailers that where built in the late '40's. I remember that they both had air brakes on them. I think that they were something like 28' long.
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 27' was a standard length for single axle semitrailers in antiquity. 35' tandems existed before overall length laws were changed to allow 40', then 42', 45', 48' and now 53'. 1951 3800 Be the change you want to see. -hotshoe
