| | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 15 New Guy | | New Guy Joined: Mar 2008 Posts: 15 | Several companies offer front and rear multileaf springs designed to lower your truck. I was wondering if anyone had any experience with these. I have a 54 3100 truck that I just bought and am starting to think about projects.........thanks | | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | I'm also interested in this. I'm in the process of lowering my '54 Suburban using a 3" dropped axle and am wondering if any companies make a new 2" drop front spring pack.
Any help would be greatly appreciated.
Dirty | | | | | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | I've wondered about suspension travel with a lowered spring. It seems the front end would bottom out easily if you lowered it much with springs, while a drop axle would leave you with the full amount of travel. | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | Does no one lower their ride by heating up the leaf springs with a torch anymore? Not that I would recommend doing something like that, but didn't the "oldtimers" do it that way? Bluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | they sure did but with varying degrees of sucess. I remember a friend doing it and had to "re-visit" the attempt several times before he got it sitting "even". Worked though.
I'm amazed at the current style of "lowering" vehicles. My friend calls them "road sniffers" but hey, I can remember back in my days the thing was how HIGH you could get the front end of the 55'ish chevs or how LOW you could get the rear bumper!! Aw, those were the days. I can stand just about anything but the puke mufflers. Makes me want to throw up! | | | | | Joined: Mar 2008 Posts: 15 New Guy | | New Guy Joined: Mar 2008 Posts: 15 | When I was a kid we would use lowering blocks for the leafs and either heat the front coils or cut them. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I remember when the "rake" was popular and we would raise the rear. I remember my 51 Chevy two door of which I raised the rear by putting 4" wooden blocks between the spring eyes and shackles. It raised it alright but the ride was tooth jarring. That lasted about 2 days and a few headaches.
~Jim
| | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Monoleafs !
Easy to install, lower front by 3-1/2" and never bottom out. Also higher load capacity, safer and smoother ride than multileaf springs.
Cheapest way to drop the rear are lowering blocks.
...never heat suspension or steering parts! Spring shops can de-arch leaf springs the right way for little $$. | | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | I am actally working with a company right now on installing composite(not metal) mono leaf springs front and back.
These will lower the truck some, and more significantly cut the unsprung weight from 142 pounds of springs down to only 25 pounds of springs TOTAL (all 4 leaf springs). That should improve suspension performance a LOT.
We have the springs alreayd made, and are now working on the metal mounts to ensure they will fit the stock spring mounts, shackles, pins, and bushings.
I should hvae more to post in afew days.
Jim G | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I al;so went with the TCI setup for the rear leaf springs.The entire kit was around $600. with sway bar.It also came with very good instructions. Mine is a 55 2nd series o I had to flip the rearend.The new springs are 5 leaf,which are now below the rearend.New spring mounts shackles, shocks,shock mounts,etc. plus sway bar.I used the TCI IFS in front with power R&P steering.I think the truck looks good.It rides and handle very good. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i went with chassis engineering they offer a bolt in kit.2 1/2 springs with teflon buttons,upper and lower shock mounts,shocks,spring saddles all hardware and very simple instruction.you actually use some of the stock holes to help align everything.very easy to install.i also got the sway bar option.it was 479.00 for the kit and 129.00 for the sway bar.got almost a 5" drop in the rear and the upper shock bar makes a good mount for the fuel cell............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
