Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (GMCJammer51, Bill Hanlon, 3B), 58 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#397241 04/03/2008 5:12 PM
Finally got my truck back on the road. Have a few minor tuning issues I could use your suggestions on. Motor is a bored 327 with a mild cam, new Edelbrock 600 cfm carb on a Performer intake manifold, electronic ignition, mechanical fuel pump / fuel pressure reg. set at 6 psi. Starts, idles, and runs good. If I accelerate smoothly, no issues. If I stomp the gas, hesitation & backfire. Also, doesn't like to run a constant speed - ie @ 50 mph, kinda jerky. Thanks in advance !
1940 Chevy KC 1/2-Ton
Britcon #397251 04/03/2008 5:44 PM
You could try playing with the timing a little. I use the factory settings only as a baseline, and adjust (usually advance) the timing until you hear a slight ping under hard acceleration then back it off slightly. This takes some trial and error but it'll pay off.
waldo53 #397265 04/03/2008 6:29 PM
Mine hesitated too, basically the same setup. At the front part of the throttle linkage there is a plunger, it uses a tiny tiny cotter pin to attach the linkage too. Change the linkage so the pump has a longer stroke. Gives a little more gas to the motor when you step on it. Not sure about the surging though.
stea #397809 04/04/2008 9:06 PM
Hi Bruce,glad you got it finished.Things that come to my mind.
1/try 10degrees timing
2/the jerking at speed may be fuel starvation,you didn't mention a fuel fiter,the E-brock use an external filter,maybe the one you have is not flowing enough at high speed.Remove it and go for a test run
3/make sure you vacum advance is working
Hope to see you at the next lunch, Boyd
