5 members (Gdads51, Oswald, TUTS 59, MickeyP, 1 invisible), 89 guests, and 0 robots.
Topics128,049
Posts1,055,695
#39716 05/19/2005 3:05 AM
Where do you suppose is the optimum spot for the water gauge sender? Near the pump? On the block, forward? On the block towards back?
I'm gonna hook up an aftermarket gauge on my flathead six to compare with factory gauge for an upcoming 700 mile trip. The original connects to the block towards the back. And since I want both gauges working, I obviously can't use existing port. Any thoughts on location better or worse than others?
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#39717 05/20/2005 2:06 AM
I would say the higher up in the system (cylinder head), the better you'll be for getting the true temperature. Just my opinion though,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#39718 05/20/2005 5:28 PM
So try to stick as close to the outlet as possible where temps are highest before going back to radiator? Makes sense. I'll see if I can find a spot. Thanks.
-David
My \'65 Chevy C-20
