2 members (Gdads51, 3B), 116 guests, and 3 robots.
Topics128,195
Posts1,057,379
Members48,469
#39671 03/03/2005 3:37 AM
just recieved my heat plate from langdons, it does dot fit between my offy intake and the fenton headers i have on my 54/235. i will call them in the morning but for now has anybody else had this problem? any suggestions? ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#39672 03/03/2005 3:53 AM
Please post the response you get. I had the same problem. I ground the edges down to make it fit.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#39673 03/03/2005 4:09 AM
The heat plate I got from The Stovebolt Engine Company ("Tom Langdon's") four years ago fit fine (Offenhauser dual-singles intake and Fenton headers).
Tim
#39674 03/03/2005 2:54 PM
i should take hits with a wet noodle!!!!!!! got in a hurry last night and did not take notice of the cut out in the plate. this morning in the light of day i tried it and it fits perfectly. sorry langdons. another question should i use water heat or manifold? be gentle i am not the best mechanic around would like the most simple. ron
2017 Buick Encore
See more pix
#39675 03/04/2005 2:08 AM
Maybe I'm wrong but, if you're running headers, it doesn't seem like you have much choice but to use water heat. I found it easiest to tap off from my heater hoses. Used T fittings and ran hoses over to bottom of intake.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#39676 03/04/2005 2:36 AM
I used the same plate and water heat on my 261 with dual Offy and Fentons. There is a photo of the engine compartment in the Gallery ("Silver")
52 PU. I had to grind the intake, exhaust and heat plate in a few areas but nothing overly agressive. I ran stainless steel hoses for the water lines and it turned out good.
shoeless
#39677 03/04/2005 3:19 PM
the fentons i have have ports already drilled and i have seen them done both ways. i get a lot of magazines i wish i had saved the pictures of the installations. langdons recommends water but it is slower to heat up, but exhausts more corrosive. i have a few weeks before i am going to tackle this. any more comments would be appreciated. thanks ron.
2017 Buick Encore
See more pix
#39678 03/04/2005 3:59 PM
Apprentice
Apprentice
Jim Carter Truck has a new kit from Fenton for exhaust heat
Looks good fits good on my 54
