1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | What would you all recommend for a 55 second series with a SB 350 - power or manual rack?
I am getting ready to buy an IFS kit from No limit Engineering and I am not totally sure which one to get.
Any advice would be greatly appreciated!
As a side note.....any feedback on No Limit as an IFS kit manufacturer?
Ross | | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | Let's see, small block for plenty of power, IFS for smooth ride, why would you want a manual rack to make parking it somewhat of a chore? Course, I'm over 50 so I consider those convenience factors more than I used to. | | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Good point.
I just wasn't sure how difficult it is to get the power part of the power steering hooked up.
This is my first attempt at this type of project. | | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | I haven't made the IFS conversion myself but if the kit comes with a rack, all the engineering should be done. Location of the rack and it's mounts should be straight forward. The nice thing about using the SBC is the brackets and pumps to go with power steering are easy to find (Jegs and dozens of others). Check to see if the rack is designed for a chevy pump as there is a difference in pump pressure that can cause the steering to feel over-boosted if you match a ford rack to a chevy pump. There are solutions to the problem but you should know what you are getting into up front. Other bolters may know if the No Limit kit has any problems. Good luck and let us know how it turns out. I might be there sometime next year. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If you are considering some big tires up front, power is the way to go. You can get adapters for Chevy pumps to Ford boxes if required. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The solution to the pressure issue comes in the form of a washer kit for the pump control valve. Available at most speed shops, less than $10. Fred
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I went with the TCI M2 Kit and power rack and pinion steering.I really like the power steering and it aint that much more work put it in.Just make sure your pump pressure matches the rack pressure. I used a GM power steering pump,and TCI units use a TBird rack ,so I had to get a pressure reducing valve for my pump. GM puts out 1300 PSI, whereas the TBird unit calls for 800 PSI.Anyway power is the way to go.
| | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Thanks for all of the information.
Looks like I am going with power. I will check with No Limit to see what rack is included with the kit and how much pressure the rack will require. If I recall correctly, the power rack setup comes with a matching pump.
Thanks again everyone! | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | not having the right pressure pump will blow the seals. i know i purchased a new saginaw for my pacer ifs on my 54 and it blew the seals three times, once after ten feet of driving so be very careful. even the power reducer valve didn't help.. now i have a pacer pump. ron
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hello dale937 & rfs56trk I too am fitting the Mustang2 Power rack with the Chevy pump. Can you tell me where you got your reduction valve? My buddy didn't use this on his '51' and the steering was 'twitchy' to say the least! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I bought my unit locally from a TCI dealer. When I told him of my problem,he went to his tool chest and handed me a pressure reduction valve for my GM pump.I really dont know where he originally got it from,but it worked for me.Check around at the aftermarket suppliers,Brothers,Chevy Duty,Golden State,etc.I am sure one of them will have the valve.When you buy your unit ask them what power rack they use.Like I posted before the GM pumps put out about 1300 PSI,wheras TBird units operate at 800 PSI,so the GM pump will blow the seals in a Ford rack.If the unit you are buying has a pump included you are good to go. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The last one that I did I used the washer kit from Bill's Hot Rod. It is relatively a straight foreward procedure, remove the fitting from the pump, remove the control valve, dissassemble and add the washers as indicated in the instructions, reassemble. I think it came from Speedway or Jegs. Fred
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks guys! I bought the Front end kit from Speedway. I'll contact them first and see how it goes!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I owned a '49 that I installed a MII front clip with a manual rack. While it was significantly easier to turn than the original straight axel, I often times wished that I had went with a power rack, esp. when trying to park in a tight spot.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
