| | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39647 08/13/2002 5:29 AM | Joined: Aug 2002 Posts: 2 Junior Member | | Junior Member Joined: Aug 2002 Posts: 2 | Hi all, just registered here and I thought I might be able to find out some information on identifying a Chevy engine. Its a six cylinder in a 71 C 10 pickup. The original engine was a 250 but this one has been replaced at some point in time. I'm wondering if theres any easy to spot differences between the 250 and a 292. This one really seems powerful, maybe bigger than a 250. I understand the number stamped into the block at the base of the distributor is not necessarily a way to identify the engine size. But just in case, heres the number...FO212CCA | | |
#39648 08/13/2002 6:30 AM | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | The little bit that I know is about motor mount location. The 250 has them even on both sides, the 292 are stagered. One side is closer to the radiator than the other. Also the 292 distributor is in the center of the engine and the 250 is towards the front. Joe | | |
#39649 08/13/2002 11:23 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#39650 08/13/2002 3:18 PM | Joined: Feb 2002 Posts: 5 Member | | Member Joined: Feb 2002 Posts: 5 | Rusty Identifying the deference between a 250 and 292 is easy. The side covers on a 250 will be 4" tall on a 292 will be 6" tall. You can also get year and size on the Inliners International site at: http://www.Inliners.org Ronnie
Rember to keep it INLINE!
#39651 08/13/2002 3:24 PM | Joined: Aug 2002 Posts: 2 Junior Member | | Junior Member Joined: Aug 2002 Posts: 2 | Thanks for the info. I see my engine code CCA listed in 73 and again in 77 as a 250 cubic inch so I guess thats what it is. Sure is a lively engine for a six. I have no idea how many miles are on it but it seems in decent shape, not an oil burner and runs smooth since I replaced the distributor. I'll have a few photos to post soon. | | |
