| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 4 New Guy | | New Guy Joined: Sep 2007 Posts: 4 | installed a professionaly rebuilt 350 with new holley carb in my '51.took it out for a shake down cruise and it kept stalling at stop signs.everything is new such as fuel pump,radiator,EI,plugs,wires etc.anybody have any thoughts? vapor lock? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | th,
What transmission do you run?
Stuart | | | | | Joined: Sep 2007 Posts: 4 New Guy | | New Guy Joined: Sep 2007 Posts: 4 | | | | | | Joined: Nov 2004 Posts: 23 Apprentice | | Apprentice Joined: Nov 2004 Posts: 23 | Is the carb float level set to high or maybe the float is sticking,flooding the engine?
save a camaro,run a straight axle
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I'd look at your idle circuit on the carb. Also, if it has a flat tappet cam, did you break in the cam first? Very important, you should.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Sep 2007 Posts: 4 New Guy | | New Guy Joined: Sep 2007 Posts: 4 | | | | | | Joined: Nov 2004 Posts: 23 Apprentice | | Apprentice Joined: Nov 2004 Posts: 23 | I have found that Holley carbs usually need to be adjusted,and are a bit of a PIA.You might also check for dirty fuel filters if you are using the old gas tank
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it starts right back up it's probably idling too slow. Set the idle stop screw up a little after it warms up enough for the choke to go off. A 350 pulls down quite a bit when you have it in drive. I've never seen a carb yet that didn't need some adjustments after it is put on the engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
