4 members (Otto Skorzeny, Gdads51, Opelika Tom, crenwelge), 75 guests, and 1 robot.
Topics128,062
Posts1,055,851
Members48,428
#396386 04/01/2008 8:05 PM
th
Offline
installed a professionaly rebuilt 350 with new holley carb in my '51.took it out for a shake down cruise and it kept stalling at stop signs.everything is new such as fuel pump,radiator,EI,plugs,wires etc.anybody have any thoughts? vapor lock?
th #396387 04/01/2008 8:18 PM
th,
What transmission do you run?
Stuart
th
Offline
it has a turbo 350
th #396421 04/01/2008 9:23 PM
Apprentice
Apprentice
Is the carb float level set to high or maybe the float is sticking,flooding the engine?
save a camaro,run a straight axle
I'd look at your idle circuit on the carb.
Also, if it has a flat tappet cam, did you break in the cam first? Very important, you should.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
th
Offline
arent the carbs preset?
th #396430 04/01/2008 9:31 PM
Apprentice
Apprentice
I have found that Holley carbs usually need to be adjusted,and are a bit of a PIA.You might also check for dirty fuel filters if you are using the old gas tank
Riding in the Passing Lane
If it starts right back up it's probably idling too slow. Set the idle stop screw up a little after it warms up enough for the choke to go off. A 350 pulls down quite a bit when you have it in drive. I've never seen a carb yet that didn't need some adjustments after it is put on the engine.
1972 Chevy c10 Cheyenne Super
