1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#382412 03/02/2008 4:20 PM
I had a vinyl pad made for under the hood, about 3 by 4 foot.
All attempts to glue it in place have been temporary. The heat seems to softer the glue and it starts separating from the hood.
any advice?
gazim #382420 03/02/2008 4:35 PM
Magnets.
I didn't want to was the straps on the hood part of the front end bra I bought, so I sewed magnets into. I think there like 40lb pull and are 1in sq. by 1/8in thick.
Here's the bad news, I can't remember where I ordered them.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
wilbur #382472 03/02/2008 7:25 PM
Ex Hall Monitor
Ex Hall Monitor
All of the under hood pads I've seen used the push in type of fastener. I assume because of the problem you're facing of the engine heat softening glue.
Tiny #388260 03/15/2008 9:00 AM
I don't think there is a glue tuff enough to handle the high temps under the hood. The push in fasteners Tiny talks about can be found at Tractor Supply for under a buck a piece. The magnet approach is a good idea also, the advantage being you can put a magnet wherever there isn't a brace without doing any drilling.
dj durant
More pix on Flickr
Tramp #389240 03/17/2008 6:59 PM
Well, the push in fasteners would necessitate drilling a hole thru the hood, do that isn't a consideration. the magnets either would have to be sewn on or glued on. Looks like it will have to be the resew job or I might try 3M #90, it comes in a caulk tube. Someone else mentioned it. Thanks anyway, As soon as it gets warm enough to try the new adhesive I will.
gazim #395679 03/31/2008 3:20 AM
Apprentice
Apprentice
I used beads of 3m caulking on pad and then sprayed fast drying glue to hold it in place while caulking dried, its never moved since .
wave
Moderated by  ndkid275, Phak1
