| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | Is it reasonably safe to weld on the rear axle tube to put shock mounts on? I mean as far as the welding stresses on the metal. I am working on a '34 half ton. And do I really even need shocks on this old truck? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Davy, I have NOT worked on a 34 but I think its like a 37 but maybe not. Anyway, if its like I think it is there should be a plate under the springs that the U-bolts go through. Why can't you make a plate with a bolt welded to the back of it for one end of the shock to go on....and for the top weld a small bar across the chassis with a long bolt welded to it for the top end of the shock to go on. This is what I did on my 37 and it works nice and without a lot of money.
To answer your specific question I see no reason you could not weld to the axle housing. Most folks have to weld new spring perches on rear ends all the time without problems. I think you would be fine as long as you don't "burn through" the housing. I'm sure others will chip in with their comments. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | davy, I wouldn't hesitate for a second to weld a shock mount on a axle housing. The weld will outlast all of us and will do no structural or metallurgical harm. Bust out the AWS 7018-Atomarc!  Stuart | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | Nice looking-rather, great looking pickup achipmunk. And thanks for the advice--I could use either one--thanks. Thanks for the backup on that , Atomarc
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I have all four of the original shocks off my 37 I wont be using,they do need to be rebuilt. Jeff | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | I will probably just use modern shocks I guess--My truck seems not to have had any shocks--as far as I can tell.---Thanks | | |
