3 members (BC59, 2-Ton, Forty9),
104
Mod | | | Forums66 Topics128,128 Posts1,056,685 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Looking to haul a 41 1 1/2 ton GMC with what's left of a flat bed on it.I have access to a big enough trailer but would be using my f-150 to pull it. It would be most likely a 5 1/2 hour trip with no major climbs, the worst is sea level to 1300ft in one shot then another about the same. After that only flats and small rolling hills. No brakes on trailer. Am I crazy for even thinking about doing this, the cheapest estimate I've got is about 650$, highest so far 1000$. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | The short answer is, yes. You would be crazy to try it with a 1/2-ton, heavy or not. Most especially on a trailer with no brakes. Even if it was loaded so perfectly that you could lift the tongue by hand, the tires and brakes on the towing vehicle just are not up to a random moose encounter, for example. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have to agree.
Your F-150 isn't big enough for this job. It won't do it safely based on the brakes, and those pulls up hill may challenge the truck. I'd be worried about the transmission and the cooling system.
Can you rent a bigger pickup for less money?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Am I crazy for even thinking about doing this? Yes | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | That's way too long of a trip with a trailer that has no brakes. You mentioned that you have access to it, which tells me that it's not yours, and that you're probably not used to pulling it. You could very easily find yourself in serious trouble, if you got into a panic stop situation, for example. My trailer had no brakes for many years, and I did a lot of hauling with it. But I knew what I had, and drove it accordingly. Still, I realized I was taking a chance, every time I left the yard with it. I'd never have taken it on the trip you're describing. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I was sort of thinking what you guys are saying,I also was worried about my transmission, my truck is pretty light and it has the 4.6 v8, I've hauled my 52 pickup with it and my boat which must weigh almost as much or more than the GMC but I only do it around town or to my shop which is about 15 miles away. It might be cheapest in the long run to have someone haul it and save wear and tare on my pickup and my nerves and health. If I did damage to my pickup it would make the whole trip a huge espense that I don't need. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Besides I think towing a GMC with a Ford is an automatic 14-day banishment from stovebolt.com  | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I guess that seals the deal, I won't tow it myself, don't want any kind of banishment here. Maybe we can forget I towed my 52 chevy with it, it was only about 15 miles, so I don't think that counts. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | I tow my 34 dump truck with a tandem axle 4 brake trailer with anti-sway bar and load leveling hitch with my 2001 S-10 extended cab pickup. Pickup has trailer tow trans. cooler (auto trans) and 4.3 V-6 engine. I have no problem towing and to be very conservative I don't tow over 50 mph. Weight distribution has more effect on towing then anything along with speed.
34 & 35 trucks are the greatest
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I don't agree, 35. An S-10 doesn't have the tire sidewalls, track width or wheelbase to safely move 3 tons, even with brakes. In a panic situation, too much weight would come off the steering when the trailer brakes were applied hard, and loss of control would be a very real possibility unless everything could be kept lined up straight. Without brakes, Homer52 would just be begging for a violent jackknife if he tried to avoid a fast-moving moose. You can take it easy on the drive train, but if the shyte hits the ardent supporter of sports, bad things can happen very quickly indeed.
Flat country and short, gentle grades are one thing. Alaska is another. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Nov 1995 Posts: 5,729 24601 | | 24601 Joined: Nov 1995 Posts: 5,729 | Agree about the S-10. I tried towing my '70 Chevelle SS ragtop with my S-10 Blazer many years ago. The Road was swift and severe in teaching me the errors of my ways. As long as everything was smooth, it was okay. We hit an extremis situation and all that weight very quickly overpowered the S-10 and around and around we went! It was a scary road moment that I wish never to repeat. I know some folks tow with 3/4-tons, but in John's world, nothing less than a 1-ton with duals is adequate for hauling old iron around (and a tandem axle deck over gooseneck trailer with 4-wheel electric brakes). You might say this is overkill, but I'd rather have too much truck and trailer than not enough.  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | I would HIGHLY recommend a DOT/FMCSA compliant Motor Carrier. In the long run that is almost always your best option. A compliant MC will know his truck and trailer and have the experience required in most any situation as well as having INSURANCE that will cover not only his own equipment, but also the LOAD (your truck). Please make sure to ask for DOT and MC numbers and check them at www.safersys.org/companysnapshot.aspx and also ask for a "Certificate of Insurance" that will come directly from the MC's insurance AGENT and will list YOU as a certificate holder! For more information about these numbers and how to check them feel free to visit my website www.kinetichotshot.com and run my numbers through safersys so that you will know what you should be looking for. Laterz, Gator >|--|~ | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd rather have too much truck and trailer than not enough. I absolutely agree! I don't insist on a dually 1-ton as my tow vehicle, but I can sure tell the difference between the 1-ton I used to have and using the 3/4-ton I replaced it with. The 1-ton weighed 1,000 pounds more than the 3/4- and gave a much better feeling of control and confidence. The duals in the rear would add more stability and I'm sure help a lot. I've pulled a loaded trailer with a light truck and no trailer brakes. Worst that has happened to me has been cleaning my shorts after running a red light because I could not stop. I now insist on a truck fully rated to do the job and a trailer with good working brakes.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Been towing a lot with the S-10 and back in the old days with a 1949 Chev. 1/2 ton and regular tube tires and trailers without brakes and didn't have trouble then. Main thing is to keep your speed under 55 mph. The S-10 has heavier load rear tires and overload springs and anti-lock brakes, trailer has auto as well as manual override brake application.
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | this summer i bought my 2003 2500hd, i have pulled tons of hay, tractors, trucks, farm stuff without a problem, i also have add-a-leafs to mount under it, this will give me another 2500 lbs. i have no beef with a real heavy 3/4 ton it has pulled super fine, but i guess the 2500hd is actually a 3500, just titled as 3/4 from what i understand. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | You don't say what is the weight of the truck and trailer combo. I have a 22ft rv with a dry weight of 4700 lbs. Loaded it is approaching 7000lbs which is below the 8000 lb tow rating of my f150. You will definitely need brakes on the trailer. I have made three round trips from Austin to Red River , NM pulling my trailer. I do have the towing package extra cooling for the automatic transmission. Even with that, the transmission temp exceeds 200 deg for a minute or so on a couple of the mountain pulls. Without the extra transmision cooling you might lose your transmission. Have you thought of renting a 3/4 to diesel truck and a trailer with electric brakes? If you are interested in seeing a short video of somebody doing exactly what you are considering doing, take a look at this link http://break.com/index/truck-nearly-tips-on-highway.html The driver narrowly escaped losing it after an abrupt lane change. He is carrying a truck , possibly a 1 1/2 ton , on a trailer and towing it with either an f150 or f250. I suspect he had nightmares for at least two weeks. I also expect he had to drive by a car wash and wash out the set of his truck. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Burned up a transmission and blew a radiator towing with a F-150 with too much weight. The F-150 transmission is not designed to tow real heavy stuff a long way. That's why I now drive a F-250 diesel. I wonder if you might rent a truck and trailer (local return where you got it) shouldn't be as much as the freight company would charge.
~Jim
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | 5 hour trip sounds like anchorage to homer on a non- tourist day! i don't know what was worse the year i worked in homer(coal point trading co.) the moose or the tourist. ir your refering to 5 hours total even from kenia would be a long tow. | | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | Another thing to consider is cross winds. I pulled home two 1 1/2 tons, one at a time with my '02 3/4 ton Silverado. The 41 was on a trailer, and the 42 with a tow bar. The trip was from Western Nebraska, about 310 miles each way (both from the same location).
No way, would I ever put a big bolt on a trailer without brakes, let alone pull it with anything less than a 3/4 ton truck. As far as handling goes, I had a lot better luck with the tow bar. The '42 was driveable, but all the braking had to come from my Silverado. Even though Nebraska is mostly a flat state, it was still pretty risky.
With the '41 on the trailer, it was white knuckle driving all the way (brand new heavy duty trailer with brakes on both axles). Their was a heck of a North-South cross wind, and I was headed East. Going down hills was the worst, it really wanted to get squirrely. The 41 didn't have an engine or tranny, and it filled up the whole trailer, so I couldn't get the weight distributed right. In hindsight, I probably would have been better off loading it backwards.
I agree, a one ton or bigger dually would have been a much better tow vehicle.
I wouldn't do it, especially with a 1/2 ton.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | My best buddy totalled his 67 Ford 1/2 ton when he was hauling a very large commercial generator. He got in a position to have to get on the brakes, the trailer got ahead of him, and then everything flipped over about 3 times. He was thrown out of the cab (no seatbelt) and my dog was thrown out the back. They both lucked out and suffered only a few bruises. Did I mention he had no trailer brakes? The really sad part is that he inherited the truck in low mile, pristine condition from his Grandpa who bought it new. The morale of the story is... Make sure you at least have trailer brakes. I would personally be more comfy with a truck made for towing i.e. heavy duty suspension, tranny cooler, etc... | | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | Their was a heck of a North-South cross wind, and I was headed East. John When is there NOT a north/south crosswind in NB? Or IA or pretty much anywhere on I-80? I'm a trucker and I hate that section!! I have seen more cars/trucks/whatever blown off the road/tipped over on that section than prolly anywhere else! Laterz, Gator >|--|~ | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I have pulled 2 AD Big Bolts home from Kansas in the last year With a 3/4 ton Duramax on a 20 ft bumper pull trailer with brakes and had no problems. I got startled a couple of times when I would forget I was towing and look in the mirror and see that big grille almost in the back window.My wife laghed everytime I got home and backed in the drive. She said it looks like the truck on the trailer should be towing the pickup. Cleon | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Alright folks, quit worrying, I'm not going to tow it myself, I'll let you know how it goes if I get it. Thanks, Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 3/4-ton Duramax and the 2500HD models are likely equipped and rated to pull a heavy load. My own 2500 is rated to pull 9,500 while the 3500 it replaced was rated for 10,000. My co-workers 2500HD is rated for even more using a class 5 hitch. I don't recall the exact figure but it is something like 13,000 or 14,000.
The capacity of the truck is only part of the equation. Knowing the hitch capacity is another, my 10,000 pound rated truck had a 6,000 rated hitch when I bought it. The 9,500 pound rated truck came with a 10,000 rated hitch.
If the truck is equipped to deal with the load, the 'class' of the truck doesn't really matter. I'm skeptical any 1/2-ton, even a heavy half like the F150 would really be a good safe option for pulling a 5,000 pound truck on a 1,700 to 2,000 pound trailer. It certainly would have no margin for error. And I don't even want to think about using an S-10...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | We use a 64 chev 3/4 ton for our hauling. We have a 20 ft tilt top trailer with no brakes.I brought in a 1961 c60 grain truck on the trailer with no problems but it would have been iffy in a panic stop situation. We now have a homemade wrecker boom and sling with a armstrong winch on it. We brought a school bus 50 miles from the hills in missouri worked great. If you pull heavy loads you need a 4 speed automatics will overheat and you dont have the gear ratio that you get with a granny low. Old Wolf  | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I agree, and when you factor in about 9-10 mpg with that load you are not saving much. | | |
