| | | Forums66 Topics128,154 Posts1,056,840 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 33 Apprentice | | Apprentice Joined: Oct 2007 Posts: 33 | 98 LS1, 4L60E trans from T.A. WS6 Just received the adapters for S.B. engine mounts. Just sitting in the bay right now. Choosing to sit engine level. Considering to keep emissions equipment on. Harness and computer to be done locally. Will need steering knuckles. Very close fit for Flaming River Steering column. Attempting to use stock manifolds, very close fit. Probably will have to notch frame rails. Any suggestions, please. | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | What are you doing for the harness and ecm ? if you are capable there are some harness kits avaialble for purchase for around $110.Does your fuel rail have a return on it or just the single line ? I have been researching all the parts needed for my 2006 6.0 for around a year so I may be able to help you .
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
| | | | | Joined: Oct 2007 Posts: 33 Apprentice | | Apprentice Joined: Oct 2007 Posts: 33 | Greetings; I do not have Editlive software or tuners. There is a guy fairly close by who programs ecm and will redue the harness. If I am running emissions, I wander what he will disable? I know there is anti-theft but not experienced enough to know. I have the fuel cell from the T.A. with all wires. Also have the exhaust with all sensors. Is it better to buy the program and equipment so one can do it themselves? Cheers | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Check out the following site and it will explain more in detail .I have spoken direct to John and he will help you in anyway possible http://www.speartech.com/ I was going to have Speartech rework my harness until I purchased the following from this site http://www.currentperformance.com/eng_mgt.html#Modit should get the system up and running .It includes diagrams and marked wireing connections with relays and fuses.Pretty sweet and cheaper than the rework if you understand basic wiring.Feel free to drop me a PM if I can help.
Last edited by 61 suburban; 04/01/2008 1:41 AM. Reason: spearteck link didn't come up
| | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | I am REALLY interested in the PHYSICAL FIT aspects of this project, as my buddy and I are about to start to try to fit a GM LQ9 6.0 liter engine (identical external block and most other parts to your engine).
I bought, from Street and Performance, their LS engine adaptors that adapt the LS engine block to regular SBC mounts, their bolt-in SBC mounts, and their tubular transmission crossmember (all these parts are actually made by Chassis Engineering).
The info I got from them is that the steering box clearance will be too tight, and that the steering box will need to be moved over about an inch, which is apparently not difficult and is workable. The exhaust clearance will also be tight, so we are prepard to go with anything from stock exhaust manifolds to tight clearance headers or whatever can fit without too much hassle.
We know that clearance at the front will be very tight because the LS series engines require several inches for the FEAD (front end accessory drives), and because we need to fit in a combination radiator / tranny cooler / AC condenser / shroud / electric fan. We will take some measurements once we get the engine roughly positioned.
The back of the engine on the LS is WIDER and HIGHER than the smallblock, due to the clyinder head corners. So, even though the distance from a reference engine mounting bolt hole to the back of block is 1" shorter on the LS series engine than on the SBC, we have asked the body shop to dent the firewall back just a bit.
If you have to CHANGE FEAD, the costs go ballistic, as GM offers only 3 variants (Corvette, Camaro/Firebird, or truck), and if none of them work, the after amrket ones START at over $2000 (no kidding). So, we want to try to avoid that.
We know already we will need a different (shorter) AC compressor, as the LS engine mount adaptor plate comes too far forward to allow using the stock 6.0 liter compressor in its low passenger side mount position. A shorter compressor will fit via mount adaptors.
How far back did you mount your engine in the chassis? (Use some easy-to-identify reference points, if you could, like middle rivet in the front crossmember to a clearly defined point on the engine mount). The instructions we got, which apply to the SBC, say to position the CENTER of each actual rubber engine mount bolt 15 1/8 inches rearward from the center of the middle rivet. Is that where you are, or somehwere different?
Jim G | | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Jim, Did you get one of street and performance catalogs ? They have pics of all the different accessory combinations.You will find the car applications moves the P/S up -vs- low on the truck applications.You are correct on the price WOW .My 61 will allow use of the stock system with a little frame modification.
| | | | | Joined: Oct 2007 Posts: 33 Apprentice | | Apprentice Joined: Oct 2007 Posts: 33 | There are a couple of points I will cover off: 1. I changed out the rad support, inner fender aprons, firewall to "Birchin Products" Everything is flat and smooth. The S & P bracketry in problematic for me and they have not addressed the problem like Zoops or March with the narrow frame set up. Problem is the price. I have lots of room up but not laterally. I have another source that offers straight upright brackets for alt and air. You have to change to to to the other air comp. (stock will not work) Complete set up with air comp, alt. power steering for $1400. I have the Eng. mount adapters from Advanced that change to Small block type (same as you). I seem to have lots of room up front. I cut out one half of the original cross member. (now in front of Mustang II) The 98 T.A. manifolds are quite narrow(I do not think tight fit headers are narrower. The stock manifolds though have 02 sensor bung and manifold flange sticking out. I cut the outside of the flange about 3/4 of inch. and will retap. I am trying to use the original header pipe from the T.A. My motor is sitting with about 2 inches to spare in front of firewall. I have the tubular trans mount not in yet, still have the stock cross member in. (Will have to remove it) The Mustang II power rack steering box and knuckle, shaft assembly looks like it will just slide by. (three knuckles to steering column) I have pictures of this already being done in 48 Chev P.U. The best thing would be to send you pic's directly. Cheers
| | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | Thanks! Irecievd your email with the firewall photo atatched, and am looking forward to seeing more photos when you can send them!
I don't need power steering bracket (using manual steering with original steering box and original front axle), but an AC compressor mount that gets the AC compressor UP above the passenger side of the engine would maybe be a better solution than trying to figure out the adaptor / different compressor for the existing location impeded on by the LS mount adaptor. WHERE did you get that high AC compressor mount?
Jim G | | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | I am doing the same in my 50 model with a 5.3 out of a 2006 Tahoe. why wont the stock compressor work? If you use the most common type of LS engine mount adaptors, which adapt the LS engines to regular smallblock mounts, they come forward enough on the side of the block to preclude getting the AC compressor mounted without interference. Jim G | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I have those type mount adapters, this truck has to have A/C due to our climate so I will have to come up with a solution. | | | | | Joined: Dec 2007 Posts: 198 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 198 | You and I both!
I'll keep you posted on progress we make when we get to that point.
Right now, we solved the exhaust manifold clearance problem, and are working on the steering box problem.
Jim G | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | You and I both!
Jim G I don't think I will have exhaust clearance problems because I went with a Mustang II front suspension. I will just have to see where the compressor ends up with that new crossmember.
| | | | | Joined: Oct 2008 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 43 | Any updates on this thread? I am thinking about starting a project like this one! | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | not much on mine, but you will have to move the compressor to the top, even with the mustang II crossmember | | |
