| | | Forums66 Topics128,108 Posts1,056,565 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | does anyone offer a rebuilt kit for the 216 water pump...jim carter asking 85 bucks for a new one | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | butch,
I am 93.5% sure there is no rebuild kit, but you might hunt around mainstream parts stores for the new one as this pump might not be a true 'specialty' item...you might save some $$$$.
Stuart | | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | thanks stuart..........i have everything running nice now.....then i took the truck out for a spin and came back after the test run and of course there always has to be something wrong......i saw a few drops of coolant under the water pump then i cranked it up again and saw coolant coming out the shaft on the water pump.........a 2 mile drive there was about a teaspoon of coolant on crossmember.......thanks again i think you are right..........i will have to replace it........
butch | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | butch,
Kragen lists a rebuilt pump with a 5/8" pulley for $50.99. It has a one year warranty. Item #58125.
Stuart | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | NAPA also sells the same as Kragen for about the same bucks.
Drew
| | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | thanks guys............i think i will order one tomorrow...i saw a rebuid kit on ebay for 15 bucks.......then of course 10 bucks for shipping and handling.......25 bucks to rebuild might as well add 25 more for new..........
butch | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | butch,
I am 99.9% sure there is no rebuild kit, just had to “one up” ya Stu! I’ve been looking for a kit for over a year Butch, they make more money by selling you the labor than the parts so the only way now is to either buy new or rebuilt. I bought one last summer from Rock Auto and the price was about the same as a rebuilt ($67.79 now) and the casting and pulley were very nicely made. And I AM……a picky SOB! http://www.rockauto.com/catalog/x,carcode,1326697,parttype,2208 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | its been about 2 years since i put a water pump on my 49 3600, it has the 216 and i want to say a brand new one was around 50.00 give or take a little. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | I went with a new pump from my local parts store (no core,a spare to rebuild, new pulley, etc.). Looks great but when I went to put the fan back on I discovered that the pulley shoulder under the fan was squared off instead of round like the original and interfered with the rivets on the fan. A little grinding took care of the problem but be careful. If I had used it like it was it could have led to fan blade failure. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes Don's right on that. I did have to touch the pulley in four spots with the dremel for rivet clearance. That said, The pully and hub is a single piece machined from a casting, which in my opinion is a better design than the hub and pressed pulley that it originally had. It runs much more true than before. Denny G
