BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
8 members (Leo, greenie-reddy, Deegs53, Cosmo, Otto Skorzeny, TooMany2count, DennisM, 1 invisible),
538
robot. | Key: Admin,
Mod | | Forums66 Topics126,781 Posts1,039,297 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | Wrench Fetcher Joined: Feb 2008 Posts: 70 | does anyone offer a rebuilt kit for the 216 water pump...jim carter asking 85 bucks for a new one | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | 'Bolter Joined: Jul 2004 Posts: 5,708 | butch,
I am 93.5% sure there is no rebuild kit, but you might hunt around mainstream parts stores for the new one as this pump might not be a true 'specialty' item...you might save some $$$$.
Stuart | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | Wrench Fetcher Joined: Feb 2008 Posts: 70 | thanks stuart..........i have everything running nice now.....then i took the truck out for a spin and came back after the test run and of course there always has to be something wrong......i saw a few drops of coolant under the water pump then i cranked it up again and saw coolant coming out the shaft on the water pump.........a 2 mile drive there was about a teaspoon of coolant on crossmember.......thanks again i think you are right..........i will have to replace it........
butch | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | 'Bolter Joined: Jul 2004 Posts: 5,708 | butch,
Kragen lists a rebuilt pump with a 5/8" pulley for $50.99. It has a one year warranty. Item #58125.
Stuart | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | Shop Shark Joined: Sep 2006 Posts: 2,393 | NAPA also sells the same as Kragen for about the same bucks.
Drew
| | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | Wrench Fetcher Joined: Feb 2008 Posts: 70 | thanks guys............i think i will order one tomorrow...i saw a rebuid kit on ebay for 15 bucks.......then of course 10 bucks for shipping and handling.......25 bucks to rebuild might as well add 25 more for new..........
butch | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | butch,
I am 99.9% sure there is no rebuild kit, just had to “one up” ya Stu! I’ve been looking for a kit for over a year Butch, they make more money by selling you the labor than the parts so the only way now is to either buy new or rebuilt. I bought one last summer from Rock Auto and the price was about the same as a rebuilt ($67.79 now) and the casting and pulley were very nicely made. And I AM……a picky SOB! http://www.rockauto.com/catalog/x,carcode,1326697,parttype,2208 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | Joined: Feb 2007 Posts: 513 Shop Shark | Shop Shark Joined: Feb 2007 Posts: 513 | its been about 2 years since i put a water pump on my 49 3600, it has the 216 and i want to say a brand new one was around 50.00 give or take a little. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | Joined: Aug 2005 Posts: 270 'Bolter | 'Bolter Joined: Aug 2005 Posts: 270 | I went with a new pump from my local parts store (no core,a spare to rebuild, new pulley, etc.). Looks great but when I went to put the fan back on I discovered that the pulley shoulder under the fan was squared off instead of round like the original and interfered with the rivets on the fan. A little grinding took care of the problem but be careful. If I had used it like it was it could have led to fan blade failure. | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes Don's right on that. I did have to touch the pulley in four spots with the dremel for rivet clearance. That said, The pully and hub is a single piece machined from a casting, which in my opinion is a better design than the hub and pressed pulley that it originally had. It runs much more true than before. Denny G
