7 members (Gray_Ghost, Peggy M, Wickedbass, Charles in CA, cmayna, baldeagle, pkr),
60
11
Mod | | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 15 | Will the head from an earlier 230/250 fit a later 250 engine that had an integral head.
I have a line on a rebuilt 250 out of an early 80's pick up but it has that integral head on it and I want to run an offy intake and headers. I have a 230 and can use the head off that if it'll work
Thanks in advance. Fran. | | | | | Joined: Feb 2000 Posts: 5,193 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,193 | Yes they will interchange. You will have no problem at all, the 230/250/292 heads are almost just alike, they all are with in a few cc's of each other. Just remember to not torque the left front head bolt as much as the rest of them. Actually, its all four corners, but the left front is the one to watch. Joe | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Another head to consider is the late '80s 250 2 bbl head. I know that it is an integral head, but it is supposed to be an upgraded "performance" head for the L6 and in '87 and '88 came with a dual exhaust manifold as well. | | |
